Calculating resolved turbulent kinetic energy for nonstationary flow
1 Attachment(s)
Dear Foamers,
I am struggling with the method of calculating resolved turbulent kinetic energy in LES. I have read a lot of threads and see that we can calculate TKE by: 0.5*(Uprime2Mean_XX+Uprime2Mean_YY+Uprime2Mean_ZZ) . But Uprime2Mean is calculated from: u-UMean, where UMean is time-averaged velocity. I know this should work with the statistically stationary flow. However, what if we have a nonstationary flow, like the figure below? Shouldn't we get the Uprime2Mean by subtracting ensemble-averaged velocity from the instantaneous velocity? If we use UMean, the results will be totally different. Any ideas? :) Kind Regards, Jasper |
I think in that function object the UMean and will be over whatever window you specify - its not automatically going to use the full time period.
Jasper - yes, you are right, that is the correct definition in a non-stationary flow (that is - Uprime2Mean needs to be calculated from u - Umean, but Umean must be the ensemble mean in this case).
To do the ensemble average you have to either run the simulation many many times (unlikely!) or find a homogeneous direction (eg. spanwise in a channel flow, as well as top half & bottom half) and average over that direction. To get a (statistically) good ensemble average, you need to ensure that you have a large enough homogenous direction. You can dig up the old postChannel utility, and modify/use that, to do the spatial averaging. Good luck! |
Best Regards, Jasper |
