Logan Unser
Rep Power: 6 ![]() |
Hey Foamers,
I posted yesterday but didn't get a response. I hope I can get some help if I give a fuller picture of the issue. I am running OpenFOAM8 on windows through the Windows Subsystem for Linux. I want to simulate natural convection in a pipe like so: ![]() (Sorry about my horrible paint skills) I created a mesh using gmsh and imported it as a polyMesh using gambitToFoam. checkMesh runs just fine, and I have set up the boundary conditions using the buoyantCavity tutorial as a guide. Unfortunately, when I run buoyantSimpleFoam, it will stop after the first timestep and output: Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 8-1c9b5879390b Exec : buoyantSimpleFoam Date : Apr 14 2021 Time : 16:33:54 Host : "LJU-Desktop" PID : 32164 I/O : uncollated Case : /home/logan/OpenFOAM/logan-8/run/buoyantPipe nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: Convergence criteria found p_rgh: tolerance 0.0001 U: tolerance 0.0001 h: tolerance 0.0001 "(k|epsilon|omega)": tolerance 0.001 Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave RAS { model kOmegaSST; turbulence on; printCoeffs on; alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } Creating thermophysical transport model Selecting thermophysical transport type RAS Selecting default RAS thermophysical transport model eddyDiffusivity Reading g Reading hRef Calculating field g.h Reading pRef Reading field p_rgh No MRF models present Radiation model not active: radiationProperties not found Selecting radiationModel none No finite volume options present Starting time loop Time = 0.01 DILUPBiCGStab: Solving for h, Initial residual = 1, Final residual = 0.0119179, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.941951, Final residual = 0.00615762, No Iterations 2 time step continuity errors : sum local = 0.0410995, global = 8.06205e-18, cumulative = 8.06205e-18 DILUPBiCGStab: Solving for omega, Initial residual = 0.536154, Final residual = 0.00486674, No Iterations 1 bounding omega, min: -0.084306 max: 10.2604 average: 0.214603 DILUPBiCGStab: Solving for k, Initial residual = 1, Final residual = 0.0127145, No Iterations 1 ExecutionTime = 0.15 s ClockTime = 0 s Time = 0.02 DILUPBiCGStab: Solving for h, Initial residual = 0.9075, Final residual = 0.0138294, No Iterations 1 controlDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application buoyantSimpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 10; deltaT .01; writeControl timeStep; writeInterval 1; purgeWrite 3; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss limitedLinear 0.2; div(phi,K) bounded Gauss limitedLinear 0.2; div(phi,h) bounded Gauss limitedLinear 0.2; div(phi,k) bounded Gauss limitedLinear 0.2; div(phi,epsilon) bounded Gauss limitedLinear 0.2; div(phi,omega) bounded Gauss limitedLinear 0.2; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear orthogonal; } interpolationSchemes { default linear; } snGradSchemes { default orthogonal; } wallDist { method meshWave; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p_rgh { solver GAMG; tolerance 1e-7; relTol 0.01; smoother DICGaussSeidel; } "(U|h|k|epsilon|omega)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-8; relTol 0.1; } } SIMPLE { momentumPredictor no; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; residualControl { p_rgh 1e-4; U 1e-4; h 1e-4; // possibly check turbulence fields "(k|epsilon|omega)" 1e-3; } } relaxationFactors { fields { rho 1.0; p_rgh 0.7; } equations { U 0.3; h 0.3; "(k|epsilon|omega)" 0.7; } } // ************************************************************************* // If there is anything else you need, please ask! I have been really struggling with getting this to work! |
Rep Power: 0 ![]() |
Your fvSchemes are in orthogonal mode. This only works well with pure blockMesh. Your mesh looks very tet to me. Try laplacian " default Gauss linear uncorrected;" and snGradSchemes " default uncorrected;" maybe? Probably also not ideal but better as it is just straight stolen from another tutorial.
Logan Unser
It is still stopping after the first timestep, but I'm sure it would have become a pain later, so thanks!
buoyantsimplefoam, simplefoam, stability problem |
Display Modes | |
Understanding Log Output / InitialResidual / Adjust timestep | betelgeuze | OpenFOAM Running, Solving & CFD | 4 | November 7, 2020 13:26 |
Instability in buoyantSimpleFoam | Avandri | OpenFOAM Running, Solving & CFD | 0 | August 7, 2020 16:13 |
Convergence-behaviour when changing physical timestep in steady-state simulation | stud-many | ANSYS | 0 | October 28, 2019 10:30 |
Simulation stops after writing each timestep although stopAt sets to end time | shimakasaei | OpenFOAM Running, Solving & CFD | 0 | September 18, 2019 12:44 |
error with smaller timestep ? | Thomas MADELEINE | FLUENT | 0 | August 8, 2016 13:02 |
