[Sponsors] | |||||
velocity on the boundary while adding a source term |
Sicheng Sun
Rep Power: 11 ![]() |
Hello All,
I just recently found some issues while using openFOAM. Here is the test example: a flow through a 2D pipe I just modified the simplefoam with a source term S added to the UEqn.H where S is a volume vector field which equations 10 in the y direction (and 0 in others). Now I check the velocity and pressure field over the white arrow in the figure For the pressure, on the top and bottom wall, I used 0 gradient bc, but the pressure gradient is not 0 for the velocity in y direction, you can see there is a oscillation. well, since I need the gradient of the velocity on the wall, this gives me trouble. Any idea how to make the velocity more smoother? |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
| [Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 18:18 |
| Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
| DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
| Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
