Generation of velocity field by solving LNSE around base flow generated by icoFoam
Old   May 3, 2021, 10:58
Default Generation of velocity field by solving LNSE around base flow generated by icoFoam
Samarth Acharya
Samarth_2412 is on a distinguished road
I am trying to study the instability of boundary layer flows by modifying icoFoam solver to create the LNSE solver, I have made the following changes to the standard icoFoam solver, where U is the perturbation term and UB the base flow velocity
dirIcoFoam.c: (modified part in icoFoam)
fvVectorMatrix UEqn
            fvm::ddt(U)
          + fvm::div(phiB, U)
          + fvc::div(phi, UB)
          - fvm::laplacian(nu, U)
In createFields.H, added the following
Info<< "Reading field UB\n" << endl;
volVectorField UB
    IOobject
        "UB",
        runTime.timeName(),
        mesh,
        IOobject::MUST_READ,
        IOobject::AUTO_WRITE
    mesh
surfaceScalarField phiB
    IOobject
        "phiB",
        runTime.timeName(),
        mesh,
        IOobject::READ_IF_PRESENT,
    fvc::flux(UB)
I have successfully compiled the modified solver and also generated results of the base flow using icoFoam at the required reynolds number.
Current methodology to approach the problem:
  1. generate base flow using icoFoam
  2. use the solutions obtained at the final time step as initial file for "UB" in the "0" directory for the LNSE solver run
  3. analysis of the perturbed flow "U"
My confusions: I am confused about step 2 in my methodology, as I'm unsure whether it will be acceptable to simply take the final step in the base flow sim and neglect the previous time steps, or should i be looking to incorporate the previous time steps as well, and if so, can anyone guide me how to execute this?
Also, i would appreciate if anyone found an error in my code and made me aware of it!
Thank you
Samarth_2412 is offline   Reply With Quote
Old   March 17, 2024, 16:55
Default Regarding Test case
hari charan
saicharan662000@gmail.com is on a distinguished road
Hi Samarth,
I am trying to do some research on instability analysis on fluid flow. The modification looks good. But I didn't understand the boundary condition for UB. Did you calculate the eigenmodes for the analysis. If you had calculated the Eigen modes, How did you do that. Can you help me with this? If possible can you send me the test case.
saicharan662000@gmail.com is offline   Reply With Quote
boundary layer flow, icofoam, instability, linearized navier stokes, perturbation
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 17:36
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. Nkl OpenFOAM Running, Solving & CFD 19 October 10, 2019 02:42
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
