Rep Power: 0 ![]() |
Hello everyone,
I'm having a problem that possibly caused by parallel running. I'm running my case using the solver rhoSimpleFoam, the case runs perfectly in serial, but it won't run in parallel, the error message is as followed. I'm a beginner of OpenFoam and I don't know what causes this problem, could you help me to solve this problem? Thanks a lot Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _79e353b8-20201222 OPENFOAM=2012 Arch : "LSB;label=32;scalar=64" Exec : rhoSimpleFoam -parallel Date : May 10 2021 Time : 12:59:02 Host : fes-fkf125.fes-aes.de PID : 62116 I/O : uncollated Case : /home/hzh/OpenFOAM/hzh-2012/run/IGV_45Grad/IGV_45Grad_AnsaNetz_50g nProcs : 16 Hosts : ( (fes-fkf125.fes-aes.de 16) ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.0001 field U tolerance 0.0001 field "(k|omega|e)" tolerance 0.0001 Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } [13] #0 Foam::error::printStack(Foam::Ostream&)[15] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [15] #1 Foam::sigFpe::sigHandler(int) at ??:? [13] #1 Foam::sigFpe::sigHandler(int) at ??:? [15] #2 ? at ??:? [13] #2 ? in /lib64/libpthread.so.0 [13] #3 Foam::basicFvGeometryScheme::weights() constReading field U in /lib64/libpthread.so.0 [15] #3 Foam::basicFvGeometryScheme::weights() constReading/calculating face flux field phi at ??:? [13] #4 Foam::surfaceInterpolation::weights() const at ??:? [15] #4 Foam::surfaceInterpolation::weights() const at ??:? [13] #5 Foam::basicFvGeometryScheme::deltaCoeffs() const at ??:? [15] #5 Foam::basicFvGeometryScheme::deltaCoeffs() const at ??:? [13] #6 Foam::surfaceInterpolation::deltaCoeffs() const at ??:? [13] #7 Foam::fvPatch::deltaCoeffs() const at ??:? [15] #6 Foam::surfaceInterpolation::deltaCoeffs() const at ??:? [13] #8 Foam::fvPatchField<double>::snGrad() const at ??:? [15] #7 Foam::fvPatch::deltaCoeffs() const at ??:? at ??:? [13] #9 Foam::heThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::heBoundaryCorrection(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&)[15] #8 Foam::fvPatchField<double>::snGrad() const at ??:? [13] #10 ? at psiThermos.C:? [13] #11 Foam::heThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::heThermo(Foam::fvMesh const&, Foam::word const&) at ??:? [15] #9 Foam::heThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::heBoundaryCorrection(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) at ??:? [13] #12 Foam::fluidThermo::addfvMeshConstructorToTable<Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:? at ??:? [15] #10 ?[13] #13 Foam::autoPtr<Foam::fluidThermo> Foam::basicThermo::New<Foam::fluidThermo>(Foam::fvMesh const&, Foam::word const&) at ??:? [13] #14 Foam::fluidThermo::New(Foam::fvMesh const&, Foam::word const&) at psiThermos.C:? [15] #11 Foam::heThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::heThermo(Foam::fvMesh const&, Foam::word const&) at ??:? [13] #15 at ??:? [15] #12 Foam::fluidThermo::addfvMeshConstructorToTable<Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::New(Foam::fvMesh const&, Foam::word const&)? at ??:? [15] #13 Foam::autoPtr<Foam::fluidThermo> Foam::basicThermo::New<Foam::fluidThermo>(Foam::fvMesh const&, Foam::word const&) at ??:? [13] #16 __libc_start_main in /lib64/libc.so.6 [13] #17 at ??:? [15] #14 Foam::fluidThermo::New(Foam::fvMesh const&, Foam::word const&)? at ??:? [15] #15 at ??:? ? at ??:? [15] #16 __libc_start_main in /lib64/libc.so.6 [15] #17 ? at ??:? -------------------------------------------------------------------------- mpirun noticed that process rank 15 with PID 62131 on node fes-fkf125 exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- |
Vishal Garg
Rep Power: 4 ![]() |
Did you solve this problem? I am also getting almost same problem while running chtmultiregionsimplefoam.
please please reply. |
Display Modes | |
Running Fluent & CFX directly using MS MPI on Windows? | SLC | ANSYS | 2 | January 8, 2020 02:02 |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 16:38 |
Problem in running coarse mesh(on the other hand fine mesh is running) | ashokmoravaneni | OpenFOAM | 7 | July 17, 2017 04:56 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
Error using LaunderGibsonRSTM on SGI ALTIX 4700 | jaswi | OpenFOAM | 2 | April 29, 2008 10:54 |
