Question regarding transient solvers and steadyState |
May 13, 2021, 19:23 |
Rep Power: 6 |
Hello to all,
I would like to know to following: Why do transient solvers (e.g., rhoPimpleFoam) have the steady-state option available in fvSchemes? Can I run rhoPimpleFoam in steady-state (although the solver is used for transient simulations..)? If the time derivatives are set to 0, the transient formulation should become the steady-state formulation. This is correct, right? For a case study, I am running the aerofoilNACA0012 tutorial with rhoPimpleFoam with ddt schemes as steadyState (just to see if it runs). However, at the first iteration the solver diverges. Giving: Code:
Creating finite volume options from "system/fvOptions" Selecting finite volume options type limitTemperature Source: limitT - selecting all cells - selected 16000 cell(s) with volume 4.1993135 Courant Number mean: 5467.174 max: 121506.46 Starting time loop Courant Number mean: 5467.174 max: 121506.46 Time = 1 PIMPLE: iteration 1 #0 Foam::error::printStack(Foam::Ostream&) at ~/OpenFOAM/OpenFOAM-v2012/src/OSspecific/POSIX/printStack/printStack.C:237 #1 Foam::sigFpe::sigHandler(int) at ~/OpenFOAM/OpenFOAM-v2012/src/OSspecific/POSIX/signals/sigFpe.C:126 #2 ? in /lib/x86_64-linux-gnu/libpthread.so.0 #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ~/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/fields/Fields/scalarField/scalarField.C:125 (discriminator 3) #4 Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) at ~/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/fields/Fields/scalarField/scalarField.C:125 #5 Foam::diagonalSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ~/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/matrices/lduMatrix/solvers/diagonalSolver/diagonalSolver.C:71 #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ~/OpenFOAM/OpenFOAM-v2012/src/finiteVolume/fvMatrices/fvScalarMatrix/fvScalarMatrix.C:181 (discriminator 1) #7 Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ~/OpenFOAM/OpenFOAM-v2012/src/finiteVolume/lnInclude/fvMatrixSolve.C:95 #8 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ~/OpenFOAM/OpenFOAM-v2012/src/finiteVolume/fvMesh/fvMesh.C:552 #9 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in ~/OpenFOAM/OpenFOAM-v2012/platforms/linux64GccDPInt32Debug/bin/rhoPimpleFoam #10 Foam::fvMatrix<double>::solve() in ~/OpenFOAM/OpenFOAM-v2012/platforms/linux64GccDPInt32Debug/bin/rhoPimpleFoam #11 ? in ~/OpenFOAM/OpenFOAM-v2012/platforms/linux64GccDPInt32Debug/bin/rhoPimpleFoam #12 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #13 ? in ~/OpenFOAM/OpenFOAM-v2012/platforms/linux64GccDPInt32Debug/bin/rhoPimpleFoam Floating point exception (core dumped) I only created the PIMPLE dictionary with: Code:
PIMPLE { nNonOrthogonalCorrectors 0; nOuterCorrectors 10; nCorrectors 3; pMinFactor 0.1; pMaxFactor 2; } If I to run a couple of transient simulations with rhoPimpleFoam and then another to check the steady solution, can't I use the same solver for both?! Best Regards |
May 14, 2021, 11:24 |
Rep Power: 14 |
Check out this earlier thread:
Steady-State with PIMPLE Yes you can run the transient solvers to solve for a steady state solution ... either with localEuler (LTS) or by choosing steadyState for the ddtScheme. Be aware that you will probably need to underrelax since you lose the stabilization of the transient term (see the discussion in the above thread). |
Transient to steady state | nikhil108 | OpenFOAM Pre-Processing | 3 | April 10, 2024 08:58 |
steadyState - Euler - different endresults | PSander | OpenFOAM Running, Solving & CFD | 0 | January 30, 2021 05:18 |
Transient to steady state | nikhil108 | OpenFOAM Running, Solving & CFD | 4 | December 14, 2020 07:50 |
convergence problem in using incompressible transient solvers. | Geon-Hong | OpenFOAM Running, Solving & CFD | 13 | November 24, 2011 05:48 |
Problem with steadyState solvers using pressure BC | Victor | OpenFOAM | 1 | December 14, 2009 05:40 |
