Ondulations/Pertubations in alpha.water surface
1 Attachment(s)
Hi all
I am experiencing some weird behaviour of the water/air interphase, see attached screenshot. I get some small ripples in my interphase between air and water. I am only using blockMesh to create the mesh, and using wave2Foam to calculate a streamfunction wave. Why to i see those ripples in the watersurface?? The models runs fine, no errors in checkMesh. I am running OpenFOAM v2012. Best Rasmus |
Bad mesh. 1. Use regular cells without these large growth rates in the region of wave propagation. 2. increase the number of subcycle for alpha : 5 3. decrease your time step Good luck. Paulin |
I resolved it from the first step you suggested. Usually I would try and keep an aspect ratio of 1, but the expansionrates were apparently the issue.. My timestep was set to dynamic. Thank you! |
