May 18, 2021, 03:28 |
K-epsilon source term fvOptions
Kabir Shariff
Rep Power: 9 |
Hello foamers,
I would like to add a source term (developed by El-kasmi, 2008) to k-epsilon model in open foam. I found a similar source term defined using the atmTurbSource in OFv2006. I copied the same file and modified the relation but I have an error in compilation. Here is the original source term defined: Code:
template<class AlphaFieldType, class RhoFieldType> void Foam::fv::myAtmAmbientTurbSource::myAtmAmbientTurbSourceEpsilon ( const AlphaFieldType& alpha, const RhoFieldType& rho, fvMatrix<scalar>& eqn, const label fieldi ) const { const auto* turbPtr = mesh_.findObject<turbulenceModel> ( turbulenceModel::propertiesName ); const volScalarField& epsilon = turbPtr->epsilon(); // (Heuristically derived from RS:Eq. 4, rhs-term:5) eqn += // fvm::Sp(alpha()*rho()*C2_*sqr(epsilonAmb_)/(kAmb_*epsilon()), epsilon); fvm::Sp(alpha()*rho()*C2_*sqr(epsilonAmb_)/(kAmb_)); } template<class AlphaFieldType, class RhoFieldType> void Foam::fv::myAtmAmbientTurbSource::myAtmAmbientTurbSourceOmega ( const AlphaFieldType& alpha, const RhoFieldType& rho, fvMatrix<scalar>& eqn, const label fieldi ) const { const auto* turbPtr = mesh_.findObject<turbulenceModel> ( turbulenceModel::propertiesName ); const volScalarField& omega = turbPtr->omega(); const volScalarField::Internal& beta = mesh_.lookupObjectRef<volScalarField::Internal> ( word(turbPtr->type() + ":beta") ); // (RS:Eq. 4, rhs-term:5) // eqn += fvm::Sp(alpha()*rho()*Cmu_*beta*sqr(omegaAmb_)/omega(), omega); eqn += fvm::Sp(alpha()*rho()*Cmu_*beta*sqr(omegaAmb_)/omega()); } template<class AlphaFieldType, class RhoFieldType> void Foam::fv::myAtmAmbientTurbSource::myAtmAmbientTurbSourceK ( const AlphaFieldType& alpha, const RhoFieldType& rho, fvMatrix<scalar>& eqn, const label fieldi ) const { const auto* turbPtr = mesh_.findObject<turbulenceModel> ( turbulenceModel::propertiesName ); const volScalarField& k = turbPtr->k(); if (isEpsilon_) { // (Heuristically derived from RS:Eq. 3, rhs-term:4) // eqn += fvm::Sp(alpha()*rho()*epsilonAmb_/k(), k); eqn += fvm::Sp(alpha()*rho()*epsilonAmb_); } else { // (RS:Eq. 3, rhs-term:4) // eqn += fvm::Sp(alpha()*rho()*Cmu_*omegaAmb_*kAmb_/k(), k); eqn += fvm::Sp(alpha()*rho()*Cmu_*omegaAmb_*kAmb_); } } Code:
In file included from myAtmAmbientTurbSource.H:259:0, from myAtmAmbientTurbSource.C:29: myAtmAmbientTurbSourceTemplates.C: In instantiation of ‘void Foam::fv::myAtmAmbientTurbSource::myAtmAmbientTurbSourceK(const AlphaFieldType&, const RhoFieldType&, Foam::fvMatrix<double>&, Foam::label) const [with AlphaFieldType = Foam::geometricOneField; RhoFieldType = Foam::geometricOneField; Foam::label = int]’: myAtmAmbientTurbSource.C:170:9: required from here myAtmAmbientTurbSourceTemplates.C:106:49: error: no matching function for call to ‘Sp(const Foam::dimensioned<double>&)’ eqn += fvm::Sp(alpha()*rho()*epsilonAmb_); ^ myAtmAmbientTurbSourceTemplates.C:106:49: note: candidates are: In file included from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/finiteVolume/lnInclude/fvmSup.H:165:0, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/finiteVolume/lnInclude/fvm.H:49, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/TurbulenceModels/turbulenceModels/lnInclude/linearViscousStress.C:30, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/TurbulenceModels/turbulenceModels/lnInclude/linearViscousStress.H:116, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/TurbulenceModels/turbulenceModels/lnInclude/Stokes.H:45, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/TurbulenceModels/turbulenceModels/lnInclude/laminarModel.C:30, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/TurbulenceModels/turbulenceModels/lnInclude/laminarModel.H:201, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/TurbulenceModels/incompressible/lnInclude/turbulentTransportModel.H:49, from myAtmAmbientTurbSource.H:118, from myAtmAmbientTurbSource.C:29: /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/finiteVolume/lnInclude/fvmSup.C:102:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::Sp(const Internal&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) Foam::fvm::Sp ^ /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/finiteVolume/lnInclude/fvmSup.C:102:1: note: template argument deduction/substitution failed: In file included from myAtmAmbientTurbSource.H:259:0, from myAtmAmbientTurbSource.C:29: myAtmAmbientTurbSourceTemplates.C:106:49: note: cannot convert ‘Foam::operator*<Foam::dimensioned<double> >((*(const Foam::one*)(& Foam::operator*((*(const Foam::oneField*)(&(& alpha)->Foam::geometricOneField::operator()())), (*(const Foam::oneField*)(&(& rho)->Foam::geometricOneField::operator()()))))), (* &((const Foam::fv::myAtmAmbientTurbSource*)this)->Foam::fv::myAtmAmbientTurbSource::epsilonAmb_))’ (type ‘const Foam::dimensioned<double>’) to type ‘const Internal& {aka const Foam::DimensionedField<double, Foam::volMesh>&}’ eqn += fvm::Sp(alpha()*rho()*epsilonAmb_); Kindly assist me in debugging please. Kabir |
May 18, 2021, 05:42 |
Michael Alletto
Rep Power: 15 |
fvm::Sp(alpha()*rho()*C2_*sqr(epsilonAmb_)/(kAmb_)) |
May 18, 2021, 06:28 |
Kabir Shariff
Rep Power: 9 |
I have now modified the equations. All variables like epsilonAmb_, kAmb_ were declared as constant in boundary conditions. All parameters are explicit now, I have suppressed all depending on implicit terms in.C file because it's not needed in the new equation.
Here is the error I am unable to debug now Code:
myAtmAmbientTurbSource.C: In constructor ‘Foam::fv::myAtmAmbientTurbSource::myAtmAmbientTurbSource(const Foam::word&, const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)’: myAtmAmbientTurbSource.C:155:1: error: expected ‘{’ before ‘void’ void Foam::fv::myAtmAmbientTurbSource::addSup // I have checked but there is no unclosed {} ^ In file included from myAtmAmbientTurbSource.H:259:0, from myAtmAmbientTurbSource.C:29: myAtmAmbientTurbSourceTemplates.C: In instantiation of ‘void Foam::fv::myAtmAmbientTurbSource::myAtmAmbientTurbSourceK(const AlphaFieldType&, const RhoFieldType&, Foam::fvMatrix<double>&, Foam::label) const [with AlphaFieldType = Foam::geometricOneField; RhoFieldType = Foam::geometricOneField; Foam::label = int]’: myAtmAmbientTurbSource.C:170:9: required from here myAtmAmbientTurbSourceTemplates.C:108:49: error: no matching function for call to ‘Sp(const Foam::dimensioned<double>&)’ eqn += fvm::Sp(alpha()*rho()*epsilonAmb_); Kabir |
May 18, 2021, 07:50 |
Michael Alletto
Rep Power: 15 |
What is line number 155 where the error occurred
May 18, 2021, 09:35 |
Kabir Shariff
Rep Power: 9 |
This is the line 155
void Foam::fv::myAtmAmbientTurbSource::addSup //line 155 ( fvMatrix<scalar>& eqn, const label fieldi ) { if (fieldi == 1) { myAtmAmbientTurbSourceK ( geometricOneField(), geometricOneField(), eqn, fieldi ); return; } if (isEpsilon_) { myAtmAmbientTurbSourceEpsilon ( geometricOneField(), geometricOneField(), eqn, fieldi ); } else { myAtmAmbientTurbSourceOmega ( geometricOneField(), geometricOneField(), eqn, fieldi ); } } Now I have these error ( a & b) and are repeated in several lines in the code (a) Code:
myAtmAmbientTurbSourceTemplates.C:114:58: error: no matching function for call to ‘Sp(Foam::tmp<Foam::DimensionedField<double, Foam::volMesh> >)’ eqn += fvm::Sp(alpha()*rho()*Cmu_*omegaAmb_*kAmb_); // corresponing line 114 is shown in blue below void Foam::fv::myAtmAmbientTurbSource::myAtmAmbientTurbSourceK ( const AlphaFieldType& alpha, const RhoFieldType& rho, fvMatrix<scalar>& eqn, const label fieldi ) const { /* const auto* turbPtr = mesh_.findObject<turbulenceModel> ( turbulenceModel::propertiesName ); //const volScalarField& k = turbPtr->k(); */ if (isEpsilon_) { // (Heuristically derived from RS:Eq. 3, rhs-term:4) // eqn += fvm::Sp(alpha()*rho()*epsilonAmb_/k(), k); eqn += fvm::Sp(alpha()*rho()*epsilonAmb_); } else { // (RS:Eq. 3, rhs-term:4) // eqn += fvm::Sp(alpha()*rho()*Cmu_*omegaAmb_*kAmb_/k(), k); eqn += fvm::Sp(alpha()*rho()*Cmu_*omegaAmb_*kAmb_); } } Code:
myAtmAmbientTurbSourceTemplates.C:83:53: note: candidate expects 2 arguments, 1 provided eqn += fvm::Sp(alpha()*rho()*Cmu_*sqr(omegaAmb_)); // corresponding line 83 is shown in blue below template<class AlphaFieldType, class RhoFieldType> void Foam::fv::myAtmAmbientTurbSource::myAtmAmbientTurbSourceOmega ( const AlphaFieldType& alpha, const RhoFieldType& rho, fvMatrix<scalar>& eqn, const label fieldi ) const { /* const auto* turbPtr = mesh_.findObject<turbulenceModel> ( turbulenceModel::propertiesName ); const volScalarField& omega = turbPtr->omega(); const volScalarField::Internal& beta = mesh_.lookupObjectRef<volScalarField::Internal> ( word(turbPtr->type() + ":beta") ); */ // (RS:Eq. 4, rhs-term:5) // eqn += fvm::Sp(alpha()*rho()*Cmu_*beta*sqr(omegaAmb_)/omega(), omega); eqn += fvm::Sp(alpha()*rho()*Cmu_*sqr(omegaAmb_)); } |
May 18, 2021, 10:30 |
Michael Alletto
Rep Power: 15 |
Did you try
fvc::Sp(alpha()*rho()*C2_*sqr(epsilonAmb_)/(kAmb_)) |
May 26, 2021, 09:15 |
#7 | |
Kabir Shariff
Rep Power: 9 |
I have check how implicit and explicit terms are applied. the implicit is in the form of Code:
fvc::Sp(A,B) Code:
eqn += alpha()*rho()*epsilonAmb_;; The problem now is that the source term is applied in the entire domain not only the region I defined as topoSet. Here are the results without source and with a source at disc region. How do I limit the source term to the cellSet region only, please? Thank you |
June 2, 2021, 06:41 |
Kabir Shariff
Rep Power: 9 |
Here is my topoSet Dict Code:
// sourceDisk1 { name sourceDisk1CellSet; type cellSet; action new; source cylinderToCell; sourceInfo { radius 0.135; p1 (5.9 2.5 0.225); p2 (6.1 2.5 0.225); } } { name sourceDisk1; type cellZoneSet; action new; source setToCellZone; sourceInfo { set sourceDisk1CellSet; } } Thank you. |
June 2, 2021, 08:31 |
#9 |
Michael Alletto
Rep Power: 15 |
You can specify for a fvoption the cellset where it is applied
June 2, 2021, 09:04 |
#10 |
Kabir Shariff
Rep Power: 9 |
Here is my fvOptions, I have specified the location defined in topoSet for myAtmTurbSource as follows:
disk1 { type actuationDiskSource; variant Froude; selectionMode cellSet; cellSet actuationDisk1; diskArea 0.50265; diskDir (1 0 0); writeToFile true; sink true; Cp 0.42; Ct 0.83; monitorMethod cellSet; cellSet actuationDisk1; } atmAmbientTurbSource1 { type atmAmbientTurbSource; atmAmbientTurbSourceCoeffs { selectionMode cellSet; cellSet actuationDisk1; kAmb 0.0216; // +15% epsilonAmb 3.725e-3; } } |
June 5, 2021, 04:28 |
#11 |
Michael Alletto
Rep Power: 15 |
How do you know the fvoption applies in the whole domain and not only in the cellset you specified
June 8, 2021, 09:00 |
#12 | |
Kabir Shariff
Rep Power: 9 |
(a) The profile without source is decaying as expected (b) the profile with a source at the disc maintains the kAmb and epsilonAmb throughout the domain. Moreover, when I used the 'select all' instead of 'cellset' (actuatorDisc) the result is also the same as the source in the disc region only. |
June 11, 2021, 10:59 |
#13 |
Kabir Shariff
Rep Power: 9 |
I think I found the reason why the source term is applied in the whole domain instead of the region defined. I run a simulation of the channel with the source term but without the actuator disc to see the effect of the source term. From my simpleFoam log, I found this: Code:
Creating finite volume options from "constant/fvOptions" Selecting finite volume options type atmAmbientTurbSource Source: atmAmbientTurbSource1 - selecting cells using cellZone zone1 - selected 12325 cell(s) with volume 0.0929195759224 Applying atmAmbientTurbSource to: epsilon and k Starting time loop turbulenceFields turbulenceFields: storing fields: turbulenceProperties:I How can I change it to Applying atmAmbientTurbSource to: zone1 ? Here is my fvOptions and topoSet fvOptions: Code:
object fvOptions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // atmAmbientTurbSource1 { type atmAmbientTurbSource; atmAmbientTurbSourceCoeffs { selectionMode cellZone; cellZone zone1; kAmb 0.0096; // +10% epsilonAmb 1.1e-3; } } Code:
object topoSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // actions ( { name box1b; type cellSet; action new; source boxToCell; box (3.8 2.4 0.4) (4.2 2.6 1.6); } { name zone1; type cellZoneSet; action new; source setToCellZone; set box1b; } ); - Kabir |
June 12, 2021, 16:16 |
#14 |
Joachim Herb
Rep Power: 21 |
The documentation https://www.openfoam.com/documentati...urbSource.html says:
// Mandatory (inherited) entries (unmodifiable) selectionMode all; So you can expect, that your source is applied in the whole flow domain. Are you using OpenFOAM.com or OpenFOAM.org? For the first one, here is another example: https://develop.openfoam.com/Develop...gSource.C#L193 |
June 15, 2021, 06:42 |
#15 | |
Kabir Shariff
Rep Power: 9 |
Hi, I am using OpenFOAM.com, specifically v2006. Thanks, I will check the new example. |
error, fvoptions, k-epsilon turbulence, source terms |
Adding source term with fvOptions to k-e model | Tibo99 | OpenFOAM Programming & Development | 20 | March 15, 2023 07:12 |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
Source term for EVAPORATION in Energy Equ. - technical difficulty ? | Kummi | OpenFOAM | 1 | September 9, 2019 09:32 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
