Ste07 |
June 15, 2021 10:19 |
Distributed Heat Source - fvOptions (chtMultiRegionFoam)
Good morning,
I'm pretty new to the OpenFOAM stuff and I'm currently facing the following problem. I would like to solve a multi-region problem (solver: chtMultiRegionFoam) with solid and fluid, some of the solid regions should produce power (different per each region). This has been set with the following fvOptions file
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object fvOptions;
heat_dwn
type scalarCodedSource;
active true;
name sourceTime;
scalarCodedSourceCoeffs
selectionMode cellZone;
cellZone heat_dwn;
fields (h);
codeInclude
codeCorrect
codeAddSup
const Time& time = mesh().time();
const scalarField& V = mesh_.V();
scalarField& heSource = eqn.source();
const labelList& cellIDs = cells();
forAll(cellIDs, i)
label cellI = cellIDs[i];
heSource[cellI] = -1305525.64*V[cellI]; // net power 1 kW
codeSetValue
// Dummy entry. Make dependent on above to trigger recompilation
code
$codeInclude
$codeCorrect
$codeAddSup
$codeSetValue
sourceTimeCoeffs
$scalarCodedSourceCoeffs;
The names of the heat regions are heat_dwn, heat_dx and heat_sx and the power they should produce is not the same. I write 3 fvOptions file (one per each region) with the specified value, but when running the case the solver uses only the input from heat_dwn (which is the one read first) ignoring the others.
For instance the previous value of 1305525.64, will be set per each region.
Has anyone ever faced this kind of issue?
Thanks in advance
Regards
