Spurious inlet pressure wave in low-Mach reactingFoam case
I am running a simple internal flow case with reactingFoam. The geometry is a back-facing step with periodic boundary conditions in the spanwise direction. To test the case, I turned reactions off and chemistry off. (In fact, I have modified the solver with YEqn.H removed so as not to transport species at all. The behavior persists.) Reactions will eventually be turned on so I am trying to get the reactingFoam, no reactions case to work first.
The inlet temperature boundary is set to 1500 K with the idea for hot gas to propagate into the domain. The Mach number is on the order of 0.01 (U_infinity = 6 m/s). I have initialized the velocity with the mean velocity from an incompressible case run with pimpleFoam (via mapFields). The inlet velocity is a parabolic profile combined with the LEMOS inflow generator. I have also tried running with this generator turned off and the behavior still occurs. For grad(U) and div(phi, U) schemes, I have tried Gauss linear and cellLimited Gauss linear 1. The behavior still occurs. The ICs/BCs are: * Initial conditions: + U: Mapped mean velocity from the ico case + p: uniform 100000 + T: uniform 300 + nut: uniform 0 + alphat: uniform 0 * Inlet: + U: fixedValue (parabolic profile) + p: zeroGradient + T: fixedValue 1500 + nut: calculated + alphat: calculated * Outlet: + U: zeroGradient (also have tried pressureInletOutletVelocity) + p: totalPressure (also have tried waveTransmissive) + T: zeroGradient + nut: calculated + alphat: calculated * Front/Back Walls: Cyclic for all conditions. * Top/Bottom walls: + U: No-slip (wall-resolved LES) + p: zeroGradient + T: fixedValue 300 + nut: fixedValue 0.0 (WRLES) + alphat: fixedValue 0.0 The pressure waves propagate as shown in the gif below. Has anyone encountered this? It is as if a shock occurs at the inlet. The pressure waves blow up the case eventually. https://s6.gifyu.com/images/twoView_pSlice_U_Xslice.gif |
