How to restart cases with updated model properties
Hi, I have a case that runs to 100 s and reaches steady state. I want to know if I change the thermo properties under folder "constant", how the results can change.
I want to know to do this, can I directly revise the number and run with latestTime? Or should I use some utilities to update the property number? Thank you! |
If you do so, you take the last result as the new starting point. It depends whether that is what you wish to calculate.
In principle it means that you have some kind of equilibrium and there change some of the materials. |
