Figuring out how mu_eff and alphaeff are calcualted for reactingFoam
Hey Foamers
I am looking at the reactingFoam solver in OpenFOAM 8 and trying to understand how the energy and species equations are solved. In energy equation: fvScalarMatrix EEqn ( fvm::ddt(rho, he) + mvConvection->fvmDiv(phi, he) + fvc::ddt(rho, K) + fvc::div(phi, K) + ( he.name() == "e" ? fvc::div ( fvc::absolute(phi/fvc::interpolate(rho), U), p, "div(phiv,p)" ) : -dpdt ) + thermophysicalTransport->divq(he) == reaction->Qdot() + fvOptions(rho, he) ); EEqn.relax(); fvOptions.constrain(EEqn); EEqn.solve(); thermophysicalTransport->divq(he) is calculated for the turbulent part as template<class TurbulenceThermophysicalTransportModel> tmp<fvScalarMatrix> eddyDiffusivity<TurbulenceThermophysicalTransportM odel>::divq ( volScalarField& he ) const { return -fvm::laplacian(this->alpha()*this->alphaEff(), he); } Similarly for species transport equation, the laplacian term is calcualted based on template<class TurbulenceThermophysicalTransportModel> tmp<fvScalarMatrix> eddyDiffusivity<TurbulenceThermophysicalTransportM odel>::divj ( volScalarField& Yi ) const { return -fvm::laplacian(this->alpha()*this->DEff(Yi), Yi); } I understood until here, but I could not figure out how both DEff and alphaEff are calculated. Has someone looked into how these are calculated ? |
Well, muEff as the other one is the dynamic part plus the turbulent part. So muEff is the dynamic viscosity plus the part that comes from the turbulence models. I updated the section in my book already (but not published) regarding such things. I think, I am going to re-update the book after FOAM v9 is out.
So the muEff is calculated in the turbulence classes. I would not agree that you are in the correct classes. I once thought that we are in the eddy viscosity class but I guess we are not. Simply use a GDB to check out where you go. I donīt have time right now. |
Hey Tobias
Thank you for the quick reply! I will check which classes are getting called to backtrack it |
