June 23, 2021, 04:39 |
Dakota parallel
Johnny Mercurial
Rep Power: 4 |
Hi everyone,
I hope my post won't be off topic, here is my question : I aml currently using Dakota 6.13 with OpenFoam 2012 in order to optimize parameters, and I am trying to build a surrogate-based optimization. The thing is I want to run several OpenFOAM in parallel to reduce the calculation time. Does anyone have already done something similar ? The OpenFOAM simulation I use runs on 6 processors and here is my dakota input file : Code:
environment tabular_data method id_method = 'SBGO' surrogate_based_global model_pointer = 'SURROGATE' method_pointer = 'SOGA' max_iterations = 15 replace_points output verbose method id_method = 'SOGA' soga seed = 10983 max_function_evaluations = 30000 #initialization_type unique_random output silent model id_model = 'SURROGATE' surrogate global dace_method_pointer = 'SAMPLING' #correction additive zeroth_order gaussian_process dakota method id_method = 'SAMPLING' sampling samples = 50 seed 531 sample_type lhs model_pointer = 'TRUTH' model id_model = 'TRUTH' single interface_pointer = 'TRUE_FN' variables active uncertain uniform_uncertain 4 descriptors 'came_start' 'stiffness1' 'stiffness2' 'stiffness3' lower_bounds -210 200 1200 2600 upper_bounds -150 400 1600 3000 interface id_interface = 'TRUE_FN' analysis_drivers = 'dakota3.sh' fork work_directory named 'workdir/run' directory_tag directory_save parameters_file 'params.in' results_file 'results.out' link_files 'dakotaParameter.orig' 'transfert.py' 'ecriture_xml_v3.py' responses objective_functions=1 descriptors 'res' no_gradients no_hessians sense 'max' Johnny |
dakota, parallel |
Display Modes | |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 16:38 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
simpleFoam in parallel issue | plucas | OpenFOAM Running, Solving & CFD | 3 | July 17, 2013 11:30 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 16:49 |
