Discrepancy with convergences
Old   June 25, 2021, 05:24
Default Discrepancy with convergences
hbulus is on a distinguished road
Hello dear foamers,
I am doing external flow analysis with unstructered tet meshes. I faced with strange behaviour: Force residuals do not converge even though residuals are perfectly aligned on specific values like 10^-5. Is there anyone who can explain this situation and give me advices to improve my vision.
(For your info: momentumPredictor is opened, i suspect from this.)
Have good days!
hbulus is offline   Reply With Quote
Old   June 29, 2021, 02:46
Waov this might be hard question? Does anyone has any idea?
Old   June 29, 2021, 04:49
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Wen need the case. We cannot guess what ges wrong form these few sentences.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   June 29, 2021, 05:55
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Originally Posted by hbulus View Post
Hello dear foamers,
Have good days!
Some of these problems are unsteady in nature and even if you solve them as steady you can see that drag lifts etc keep oscillating. This is normal behaviour and observed many times.
arjun is offline   Reply With Quote
Old   July 2, 2021, 12:40
As you wish but i cannot share the polyMesh file due to prohibition of huge transfer files to outside. The case is oneram6 validation case which is fully made of unstructural tetrahedral meshes .
The other necessary files attached.
Thanks for every opinion.
Old   July 2, 2021, 12:43
Yeap, you are right but case is oneram6 validation case. There is no BL Seperation and wake production. Steady solution must exist. 0.84 mach and 3.04 aoa .
Acoustic Power Discrepancy Time4Tea FLUENT 0 August 21, 2018 10:46
Discrepancy between contour of alpha1 = 0.5 and water level from pressure probes. JamesRunnalls OpenFOAM Post-Processing 0 December 27, 2016 10:26
Discrepancy between sectional Cp and experimental results on tip (ONERA M6) pdp.aero SU2 2 March 9, 2015 21:26
Mass flow discrepancy BenMUC CFX 3 May 2, 2014 04:29
Turbomach. Estimated and observed data discrepancy Georg CFX 1 March 13, 2009 10:47
