csvFile type missing in OpenFOAM v8
Like Tree4Likes
  • 1 Post By clapointe
  • 1 Post By Marpole
  • 1 Post By HPE
Old   June 26, 2021, 14:19
Default csvFile type missing in OpenFOAM v8
Charles
Marpole is on a distinguished road
With OpenFOAM v8, when running a case, which works fine with OpenFOAM v7, it failed with an error message that uniformValue doesn't have type csvFile. Does anyone have the same issue? I attach the inlet boundary condition below.
inlet { type uniformFixedValue; uniformValue { type csvFile; nHeaderLine 4; // number of header lines refColumn 0; // time column index componentColumns (1); // data column index separator ","; // optional (defaults to ",") mergeSeparators no; // merge multiple separators file "dataTable.csv"; } }
Charles L.
Marpole is offline   Reply With Quote
Old   June 26, 2021, 17:33
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Could you try to reproduce the issue with a standard tutorial? If it can be reproduced by others, would be nice to submit a bug ticket.
Thanks for your time.
HPE is offline   Reply With Quote
Old   June 26, 2021, 22:20
Charles
Thanks Herpes,
Attached is a pitzDaily of pimpleFoam. I revised the inlet of U to include csvFile.
The model runs fine with OpenFOAM v7. When it is run with OpenFOAM v8, it failed with the following error message.
Please check and confirm. Note, in OpenFOAM v8 User Guide page U-150, csvFile is listed as an option.
Reading field U
--> FOAM FATAL ERROR:
Unknown Function1 type csvFile for Function1 uniformValue
Valid Function1 types are:
11
coded
constant
one
polynomial
scale
sine
square
table
tableFile
uniform
zero
Charles L.
Old   June 28, 2021, 14:24
clapointe is on a distinguished road
The convention for specifying data from a csv changed, see e.g. the fixedProfile.H file (fixedProfile). You'll now use the tableFile option with format csv.
Caelan
Marpole likes this.
Public git repository : https://github.com/clapointe2011/public
clapointe is offline   Reply With Quote
Old   June 28, 2021, 16:33
Charles
Thanks for your check, Caelan.
As you can see, I'm using csvFile for boundary condition type uniformFixedValue, which is different from fixedProfile. Both can read csv file but one is a profile over time and the other is a profile over space.
Is it a bug that Function1 uniformValue misses the type csvFile?
Charles L.
Old   June 28, 2021, 17:12
The fixedProfile was just an example of how the code changed -- it is clear, I think, that tableFile has replaced csvFile in version 8.
Caelan
Marpole likes this.
Old   June 28, 2021, 19:00
Charles
Thanks Caelan. Yes, you are right and I made it work per your instruction.
In version 8, there is no csvFile type. Below is the script to use tableFile.
    inlet
        uniformValue   tableFile;
        uniformValueCoeffs
            format              csv;
            nHeaderLine         0;          // number of header lines
            refColumn           0;          // reference column index
            componentColumns    (1 2 3);    // component column indices
            file                "data/velocity.csv";  // name of csv data file
            outOfBounds         clamp;      // optional out-of-bounds handling
            interpolationScheme linear;     // optional interpolation scheme
In order to use tableFile, we do in the following way as being told in How to use 2 tableFile?
<entryName> tableFile;
<entryName>Coeffs
In my case, the <entryName> is uniformValue.
ashvinc9 likes this.
Charles L.
Old   July 1, 2021, 17:00
HPE
HPE's Avatar
Happy that Caelan could act before me (thanks) - sorry for being late.
Having said that I couldn't find any particular commit in the .org repo which deprecated the "csvFile" option (or at least stating it in a commit message). Might be worth to double check if necessary.
Old   July 1, 2021, 17:27
Charles
Thanks again, Herpes, for paying attention to this thread.
The User Guide (v8) still have type csvFile printed. This could cause some confusions. I installed OpenFOAM v8 a few months ago. Because of this, I moved back to OpenFOAM v7 to work on my projects until I have time now to investigate this issue.
Charles L.
Old   July 1, 2021, 17:30
HPE
HPE's Avatar
I would stick with v8 (or even the develop branch) instead of v7 just merely because of bug fixes involving in the newer version. Just my humble opinion.
Good luck.
Marpole likes this.
p_rgh devergence with chtMutiRegionFoam in first iteration Liz1219 OpenFOAM Running, Solving & CFD 0 March 5, 2021 23:49
Trying to convert a case from laminar to turbulent (K-OmegaSST) EternalSeekerX OpenFOAM Running, Solving & CFD 7 November 1, 2020 17:16
Film cooling problem arun1994 OpenFOAM 0 October 26, 2020 10:08
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Time step continuity error lpz_michele OpenFOAM Running, Solving & CFD 0 October 12, 2015 07:05
