[Sponsors] | |||||
Rep Power: 7 ![]() |
Hi evrybody,
I am currently trying to calculate fan performance with openFoam. My mesh seems to be Ok according checkMesh and residual not so bad. The problem is that the pressure calculated is less of 20% compared to what I expect ! I use simpleFoam so I multiply the result of the pressure with the density. I attach the main files. Please tell me if you need more details ! Thank you in advance for your help. |
Uwe Pilz
Rep Power: 16 ![]() |
Pressures and forces are rather hard to calculate with high accuracy. I think the reason is:
Pressure/Force results from energy loss in turbulences. The turbulence itself is not calculated but at least partly modelled. The models give good result according fluid stream, but are less accurate of the real energy loss and the pressures joined to it.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
Thank you very much for your answer.
Some people working in my compagny confirmed that it's very difficult to get accurate value for this kind of very narrow fan. I will try to improve the result anyway. |
Uwe Pilz
Sometimes it is useful connecting (calibrating) your results with experimental data, may be with a simpler design but the same physics. You may use the simulation only for calculating the (relative) changes while optimizing the geometry.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Appling a fan inside the domain/duct | Tobi | OpenFOAM Running, Solving & CFD | 3 | April 12, 2022 06:57 |
| Efficiency Calculation in Fan | MNMK | CFX | 2 | November 16, 2020 06:26 |
| Divergence on fan calculation | Fouch | OpenFOAM Running, Solving & CFD | 1 | August 20, 2020 03:23 |
| Input method of calculation of the efficiency of the post-axial flow fan CFX-solver? | Sanghyun - PARK | CFX | 0 | March 11, 2013 00:47 |
| Turbulence Model and Accuracy of convective flux calculation | Lokesh Agrawal | Main CFD Forum | 1 | November 15, 1998 00:24 |
