Same case with smaller Geometry leads to Floating Point Exception
Old   July 5, 2021, 10:34
Default Same case with smaller Geometry leads to Floating Point Exception
Claudia
Clau.77 is on a distinguished road
Hey Guys!
my case:
- OF-8
- chtMultiRegionFoam
- geometry surrounded by air
I have attached a little sketch of my geometry. So first of all, I am managing to simulate the whole geometry.
Now I would like to cut my Geometry in half (where you see the red line). So everything stays else stays the same and I only make the blockMesh in the y-direction a bit smaller. But when I try to run the case I am always getting the floating Point Exception error (i have also attached a snapshot of that).
Does anyone have an idea why this happens?
Clau.77 is offline   Reply With Quote
Old   July 5, 2021, 16:00
Claudio Boezio
Ship Designer is on a distinguished road
Maybe if you cut the mesh at the interior some of the boundary conditions need to be adjusted. Is that final residual for h with an exponent of -54 a typical value in your experience? Are you doing a calculation about chocolate? 🍫😋
Ship Designer is offline   Reply With Quote
Old   July 6, 2021, 04:28
Claudia
Yes, i am working with chocolate for my master thesis
The boundaries should stay the same. I also tried using different boundaries but that didn't help.
I thought the value for h is pretty low too, but when I m using the whole geometry, I also get values like e-53, but it runs nevertheless... and I actually wouldn't know what to do to get a higher value.
[cfMesh] using cfMesh with interFoam ends in a Floating point exception STEFGER OpenFOAM Community Contributions 3 October 17, 2016 03:33
Floating point exception in tutorials case xujr OpenFOAM Running, Solving & CFD 0 May 21, 2015 04:31
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
Floating point error and divergence detected aannjj FLUENT 0 July 2, 2013 04:44
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
