pimpleFoam residual and iterations values for my case
Like Tree1Likes
  • 1 Post By piu58
Old   July 7, 2021, 22:39
Default pimpleFoam residual and iterations values for my case
mohammad
mostanad is on a distinguished road
Hi everybody,
I am using pimpleFoam for solving a multiphase problem. To this end, I have specified the following relaxation factors for converging the simulation through outer iterations:
relaxationFactors
    fields
        "(p)"      0.3;
    equations
        "(U)"      0.7;
As you know, it imposes 0.3/0.7 until the last outer loop, but considers no relaxation (e.g. 1) for last one. The following shows the residual values for final pimple loops:
PIMPLE: iteration 47
smoothSolver:  Solving for Ux, Initial residual = 0.00348382, Final residual = 3.33273e-09, No Iterations 12
smoothSolver:  Solving for Uy, Initial residual = 0.000400605, Final residual = 8.08511e-09, No Iterations 11
smoothSolver:  Solving for Uz, Initial residual = 0.00348381, Final residual = 7.12709e-09, No Iterations 12
GAMG:  Solving for p, Initial residual = 0.030812, Final residual = 5.75704e-09, No Iterations 14
time step continuity errors : sum local = 2.14038e-21, global = -2.15546e-29, cumulative = -1.77606e-27
GAMG:  Solving for p, Initial residual = 0.0199088, Final residual = 3.64323e-09, No Iterations 16
time step continuity errors : sum local = 1.36398e-21, global = 6.91738e-31, cumulative = -1.77537e-27
PIMPLE: iteration 48
smoothSolver:  Solving for Ux, Initial residual = 0.00344079, Final residual = 3.32801e-09, No Iterations 12
smoothSolver:  Solving for Uy, Initial residual = 0.000403059, Final residual = 8.1732e-09, No Iterations 11
smoothSolver:  Solving for Uz, Initial residual = 0.00344078, Final residual = 7.09306e-09, No Iterations 12
GAMG:  Solving for p, Initial residual = 0.0303855, Final residual = 5.38726e-09, No Iterations 13
time step continuity errors : sum local = 1.91437e-21, global = -3.69477e-30, cumulative = -1.77907e-27
GAMG:  Solving for p, Initial residual = 0.0196223, Final residual = 9.50948e-09, No Iterations 17
time step continuity errors : sum local = 3.38302e-21, global = -1.04939e-29, cumulative = -1.78956e-27
PIMPLE: iteration 49
smoothSolver:  Solving for Ux, Initial residual = 0.0034018, Final residual = 3.32441e-09, No Iterations 12
smoothSolver:  Solving for Uy, Initial residual = 0.000405759, Final residual = 8.26221e-09, No Iterations 11
smoothSolver:  Solving for Uz, Initial residual = 0.00340179, Final residual = 7.06439e-09, No Iterations 12
GAMG:  Solving for p, Initial residual = 0.0301731, Final residual = 9.54839e-09, No Iterations 15
time step continuity errors : sum local = 3.34999e-21, global = -3.40829e-30, cumulative = -1.79297e-27
GAMG:  Solving for p, Initial residual = 0.0194295, Final residual = 7.68963e-09, No Iterations 17
time step continuity errors : sum local = 2.67738e-21, global = -6.22769e-30, cumulative = -1.7992e-27
PIMPLE: iteration 50
smoothSolver:  Solving for Ux, Initial residual = 0.151223, Final residual = 9.88356e-09, No Iterations 596
smoothSolver:  Solving for Uy, Initial residual = 0.00853352, Final residual = 9.95885e-09, No Iterations 640
smoothSolver:  Solving for Uz, Initial residual = 0.151222, Final residual = 9.93596e-09, No Iterations 610
GAMG:  Solving for p, Initial residual = 0.809884, Final residual = 8.12774e-09, No Iterations 25
time step continuity errors : sum local = 7.22642e-21, global = -5.99797e-31, cumulative = -1.7998e-27
GAMG:  Solving for p, Initial residual = 0.718341, Final residual = 7.75604e-09, No Iterations 24
time step continuity errors : sum local = 7.12491e-21, global = -6.79726e-30, cumulative = -1.80659e-27
So as you see, the residuals and number of iterations for final pimple loop suddenly increases. It becomes strange to me as I increase the nOuterCorrectors or decrease the residual tolerance but it still has a very high iterations for final outer iteration. So it seems the solution is not converging through the iterations to provide a good estimation for final outer iteration. So what is your suggestion for this strange behavior?
Cheers
Mo
mostanad is offline   Reply With Quote
Old   July 8, 2021, 02:16
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
There is less to say only form this protocol. Mostly, the problem is in your case: Too complicated, to much physics, problems with the mesh.
I recommend to start with the simplest case you can construct and look what happens. Than you might think about take more details in - if that makes sense.
It is alway a good idea splitting the problem and simulate each individual.
mostanad likes this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   July 8, 2021, 03:05
mohammad
OK. As you said the physics of my multiphase problem is a bit complicated. Its something like this algorithm in every time step:
1- Solve the fluid equations in entire field (pimple or PISO)
2- Find the forces on rigid body, and calculate the rigid body's velocity by Newton's law
3- Impose the calculated rigid body velocity in the domain
So as you see, I need to do the pimple calculation for the first step in entire field, considering the region for rigid body. This requires under relaxation factors because its actually a complicated non-Newtonian problem. Therefore, my problem is that the information in rigid body region shouldn't change drastically in pimple calculation. However, by looking at my outer loops, I see the information inside the solid region is changing every outer iteration because of imposing under relaxation factor. So the question is how I can solve the fluid in rigid particles region with minor effect from outer loops or URF? previously I was using that by PISO for Newtonian, so it didn't have any outer loop and URF. But now I must use pimple for complexity in non-Newtonian. It seems the solvers like PISO suitable for non-Newtonian flows can also be a solution.
If you need any further information, please feel free to tell me. It is a complicated and interesting problem for me.
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 14:47
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 13:30
chtMultiRegionSimpleFoam turbulent case Aditya Patil OpenFOAM Running, Solving & CFD 6 April 24, 2017 23:13
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
