mpirun warning
Old   July 14, 2021, 05:35
Default mpirun warning
Fabio Bianchi
aero_eng is on a distinguished road
Goodmorning everyone,
I'm trying to run a simulation in parallel using openFoam 8 with Windows subsystem for linux (WSL). When I launch mpirun, it gives me the following warning:
WARNING: Linux kernel CMA support was requested via the btl_vader_single_copy_mechanism MCA variable, but CMA support is not available due to restrictive ptrace settings. The vader shared memory BTL will fall back on another single-copy mechanism if one is available. This may result in lower performance.
Then the simulation proceeds, but the results that it gives are as if the simulation was runned only on a single core and not in parallel.
Can anyone help me?
Thank you in advance!
aero_eng is offline   Reply With Quote
Caffa 3D code Waliur Rahman Main CFD Forum 0 May 29, 2018 00:53
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 10:20
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
