What is the meaning of "runApplication -s solid"
Dear friends:
I want to know what is the meaning of "runApplication -s solid" I have tried to run runApplication -help. but it seems runApplication doesn't has help system. Regards |
You can always create a log file and check what's happening during the execution of the command.
From https://damogranlabs.com/2020/10/run...ck-cheatsheet/:
If you want separate logs for multiple runs, you can name the log with -s option. For instance, when merging multiple parts of meshes, your script might look like this: Code:
runApplication -s inlet mergeMeshes ../mesh-inlet |
