January 30, 2021, 01:11 |
OF div schemes greatly influence the result
samuel
Rep Power: 6 |
Dear all:
I'm doing a simulation about wind aroud a flat roof. The model can be seen below. [image]https://www.cfd-china.com/assets/uploads/files/1611984747439-wholemodel.png[/img] In the reference paper, the author applied 'second order upwind' for space discretization in Fluent. And I have used the same model parameters (eg. domain size, minimum element size, boundary condition, turbulence model). simpleFOAM and realizable k-epsilon model are used. However I find that if I adopt different divergence schemes (namely, gauss upwind, linearUpwind and limitedLinear), the results will be different from each other and only the result of 'gauss upwind' agrees with that of reference paper. From what I gather, in openfoam 'gauss linearUpwind' represents 'second order upwind' which was adopted in the reference paper. But when I use 'gauss linearUpwind' for the divergence schemes in OpenFOAM, the simulated result (namely, friction velocity on roof) differs greatly from that of reference paper. In comparison, the performance improves if I adopted 'gauss upwind' which represented first order upwind. The results of different div schemes can be seen below. [image]https://www.cfd-china.com/assets/uploads/files/1611984885997-0f0345fa-d59b-4030-9578-0dcb60ab0d6f-image.png[/img] To describe my question detailedly, some details of my fvSchems and fvSolutions are also posted. Code:
ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; limited cellLimited leastSquares 1; //grad(U) $limited; grad(k) $limited; grad(epsilon) $limited; } divSchemes { default none; div(phi,U) Gauss limitedLinear 1;//bounded Gauss linearUpwind limited, Gauss upwind; turbulence bounded Gauss linearUpwind limited; div(phi,k) $turbulence; div(phi,epsilon) $turbulence; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } Code:
solvers { p { //solver PCG; //preconditioner DIC; solver GAMG; tolerance 1e-7; relTol 0.1; smoother DICGaussSeidel; } "(U|k|epsilon|omega)" { solver PBiCGStab; preconditioner DILU; //solver smoothSolver; //smoother symGaussSeidel; tolerance 1e-7; relTol 0.001; } } SIMPLE { nNonOrthogonalCorrectors 2; consistent yes; residualControl { p 1e-7; U 1e-7; "(k|epsilon|omega|f|v2)" 1e-7; } } relaxationFactors { fields { p 0.3; } equations { U 0.7; "(k|omega|epsilon).*" 0.7; } } That makes me confused. Could anyone please give me some suggestions? Thank you samuel Last edited by Samuel Twain; January 30, 2021 at 02:16. |
January 31, 2021, 13:28 |
Hrvoje Jasak
Rep Power: 33 |
You are using the wrong kind of schemes on bounded scalars - this will destabilize the solver.
If numerical diffusion is causing trouble, you can simply refine the mesh. Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
February 1, 2021, 04:05 |
#3 | |
samuel
Rep Power: 6 |
Before that, I have found that my “k” boundary type seems to be unreasonable. Originally, I used kLowReWallFunction, after changing it to kqrWallFunction, the result becomes better. This also makes me confused. According to description, kLowREWallFunction is suitable for both low and high RE condition, while kqrWallFunction is only for high RE condtion. Is kLowREWallFunction unsuitable for realizable k-epsilon turbulence model? |
August 2, 2021, 08:18 |
Rep Power: 7 |
August 2, 2021, 11:38 |
Uwe Pilz
Rep Power: 15 |
You may use Gauss upwind if you are looking for robust schemata. More accurate is linear upwind, but more oscillatory too.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
Display Modes | |
chtMultiRegionSimpleFoam div schemes | guserik | OpenFOAM Running, Solving & CFD | 2 | November 14, 2013 18:30 |
simpleFoam: case only converges with most div schemes set to upwind | buffi | OpenFOAM Running, Solving & CFD | 7 | November 11, 2013 08:54 |
Numerical schemes for grad and div | Tobi | OpenFOAM | 6 | March 11, 2013 22:24 |
Accuracy problem of HO schemes on unstructured mesh, HO scheme gives 1st order result | gemini | Main CFD Forum | 12 | December 27, 2011 22:01 |
time stepping schemes for compressible DNS/LES | shyamdsundar | Main CFD Forum | 0 | January 15, 2010 00:15 |
