Ben786 |
August 7, 2021 18:02 |
Compressible flow solving - issues with "Floating point exception"
2 Attachment(s)
Hello everyone! I'm having trouble with solving this compressible flows problem and it seems like I can't get the solver to get going no matter what I do. The most common error I'm seeing is "Floating point exception" - perhaps my Google-fu isn't strong enough, but I can't seem to find a straight answer for what this actually means.
A little background on the problem:
I'm trying to simulate a CD nozzle that takes air (1500 K, 500 m/s, 10MPa) at its inlet. I've designed the nozzle such that the flow will be fully expanded and supersonic at the exit (100 kPa). Eventually, I want to be able to simulate the addition of solid nanoparticles in the flow, but that may be way above my current understanding...
The characteristic length is the nozzle inlet diameter (0.02 m) and calculated exit speed is 1610 m/s, giving deltaT an order of magnitude of around 1e-7.
I've attached my .geo(.txt) use for my mesh and a recent error output to this post, and also relayed my settings below.
Thank you in advance to anyone willing to take the time to help me!
# 0 #
p
| \\ / O peration | Version: v2012 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 1e5;
boundaryField
inlet
// type totalPressure;
// p0 uniform 1.29036e+07;
// gamma 1.3;
// value uniform 1.29036e+07;
type fixedValue;
value uniform 1e7;
exit
// type zeroGradient;
type fixedValue;
value uniform 1e5;
top
type zeroGradient;
bottom
type zeroGradient;
front
type empty;
back
type empty;
T
FoamFile
version 2.0;
format ascii;
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 300;
boundaryField
inlet
// type totalTemperature;
// gamma 1.3;
// T0 uniform 1725;
type fixedValue;
value uniform 1500;
exit
type zeroGradient;
top
// type slip;
type zeroGradient;
bottom
// type slip;
type zeroGradient;
front
type empty;
back
type empty;
U
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type zeroGradient;
type fixedValue;
value uniform (500 0 0);
// type pressureInletVelocity;
// value uniform (0 0 0);
exit
type zeroGradient;
// type inletOutlet;
// inletValue uniform (0 0 0);
top
type slip;
bottom
type slip;
front
type empty;
back
type empty;
# System #
controlDict
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application rhoSimpleFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 0.5;
deltaT 1.7391e-07; //1.7391e-07
writeControl adjustableRunTime;
//writeControl adjustable;
//writeControl timeStep;
//writeInterval 575000;
writeInterval 0.01;
purgeWrite 0;
writeFormat ascii;
writePrecision 7;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
adjustTimeStep true;
maxCo 0.5;
maxDeltaT 1;
fvSchemes
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss vanLeerV 1;
div(phi,nuTilda) bounded Gauss vanLeer 1;
div((muEff*dev2(T(grad(U))))) Gauss linear;
// Sxx - Szz are variables for Spalart-Shur correction
div(phi,Sxx) bounded Gauss linear;
div(phi,Sxy) bounded Gauss linear;
div(phi,Sxz) bounded Gauss linear;
div(phi,Syx) bounded Gauss linear;
div(phi,Syy) bounded Gauss linear;
div(phi,Syz) bounded Gauss linear;
div(phi,Szx) bounded Gauss linear;
div(phi,Szy) bounded Gauss linear;
div(phi,Szz) bounded Gauss linear;
div(phid,p) bounded Gauss linear;
div(phiv,p) bounded Gauss linear;
div(phi,K) bounded Gauss linear;
div(phi,h) bounded Gauss vanLeer 1;
div(phi,Ekp) bounded Gauss linear;
div(phi,e) bounded Gauss linear;
div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
fvSolution
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
e
solver PBiCG;
preconditioner DILU;
tolerance 1e-8;
relTol 0;
"rho.*"
solver diagonal;
"p.*"
tolerance 1e-8;
relTol 0;
solver PBiCG;
preconditioner
preconditioner GAMG;
smoother DIC;
nPreSweeps 1;
nPostSweeps 2;
nFinestSweeps 2;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
*/ minIter 3;
maxIter 1000;
"U.*"
type coupled;
solver PBiCICG;
tolerance (1e-8 1e-8 1e-8);
relTol (0 0 0);
"h.*"
solver PBiCG;
tolerance 1e-8;
relTol 0;
"nuTilda.*"
$h;
tolerance 1e-8;
SIMPLE
nNonOrthogonalCorrectors 3; // 0
pRefCell 0;
pRefValue 0;
rhoMin rhoMin [1 -3 0 0 0] 0.1; // 0.5
rhoMax rhoMax [1 -3 0 0 0] 30; // 2.0
transonic yes;
relaxationFactors
fields
p 0.2;
rho 1.0;
equations
U 0.8;
"(e|h)" 0.8;
nuTilda 0.8;
# Constant #
thermophysicalProperties
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object thermophysicalProperties;
thermoType
type hePsiThermo;
mixture pureMixture;
transport sutherland;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleInternalEnergy;
// We refer to absolute energy where heat of formation is included, and sensible energy where it is not
mixture
specie
nMoles 1;
molWeight 28.96;
thermodynamics
Cp 1243.7;
Hf 0;
transport
As 1.458e-6;
Ts 110.4;
turbulenceProperties
FoamFile
version 2.0;
format ascii;
class dictionary;
object turbulenceProperties;
simulationType laminar;
boundary
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
6
back
type empty;
physicalType empty;
nFaces 2293;
startFace 3376;
top
type wall;
physicalType wall;
nFaces 44;
startFace 5669;
exit
type patch;
physicalType patch;
nFaces 28;
startFace 5713;
bottom
type wall;
physicalType wall;
nFaces 44;
startFace 5741;
inlet
type patch;
physicalType patch;
nFaces 11;
startFace 5785;
front
type empty;
physicalType empty;
nFaces 2293;
startFace 5796;
