Thermal contact resistance with variable thickness
Hello everyone,
I am trying to model the contact resistance between two bodies. I know that the "turbulentTemperatureCoupledBaffleMixed" is the way to go except I have a unique issue where the thickness between the two objects varies. My question is: Is it possible to simulate a variable thickness for the thermal contact resistance? And if so, how? Unfortunately I cannot share the case file as it is sensitive but this is what I have in my 0/T folder for the said BC: targetToCopper { type compressible::turbulentTemperatureCoupledBaffleMix ed; value $internalField; Tnbr T; kappa solidThermo; kappaName none; thicknessLayers (2.5e-7); //Use average since cannot make variable kappaLayers (0.016); } Basically what I want is to have my layer thickness follow a certain function dependent on coordinates, for example: thickness = f(x,z coordinates) Any help is definitely appreciated. Thanks! |
