Residual plot is varying after some iterations |
September 16, 2021, 22:01 |
Chaitanya kishore
Rep Power: 4 |
The steady state simulation is done and obtained an residual plot. Residuals values are below 10^-6 but after that varying. Do I have to perform transient simulation or can I modify some parameters to decrease those variations here only?
Image is attached here. https://drive.google.com/file/d/1xJk...ew?usp=sharing |
September 18, 2021, 08:01 |
Rep Power: 20 |
Check your solution tolerance in fvSolution. You'll find something like this:
p_rgh { solver GAMG; smoother GaussSeidel; tolerance 1e-06; relTol 0.05; } Which means either solving down to a tolerance of 1e-6 or reducing it to 0.05 of the previous value. Hence once you reach the tolerance values below it are by chance a bit below 1e-6 or quite a lot. You could reduce this tolerance further if needed. This wiggling will occur however once you reach the solution threshold. |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 13:47 |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 12:50 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
