-   OpenFOAM Running, Solving & CFD (https://www.cfd-online.com/Forums/openfoam-solving/)
-   -   [GUIDE] Switching from incompressible to compressible simulation (https://www.cfd-online.com/Forums/openfoam-solving/238268-guide-switching-incompressible-compressible-simulation.html)
gabrielfelix September 2, 2021 08:11
Hi folks
I'm simulating a propeller in steady-state incompressible flow using simpleFoam with the same boundary conditions as the pimpleFoam or pimpleDyMFoam marine propeller tutorial. I wanted to run my case in compressible flow and I faced some problems to which I could not find a direct guide to overcome them. I saw that there are many posts concerning the same problems I had, and I decided to create this guide, now that I managed to succesfully run my case with rhoSimpleFoam.
I tried to apply the same file configurations of the rhoSimpleFoam aerofoilNACA0012 tutorial in my case, however I had to make other modifications to be able to run the case.
I'm not expert on this compressible configurations, so the solutions I will come up here might not be the most adequate ones, but rather the ones I managed to run my case with after researching in many and many threads.
1. Add the alphat and T files to 0/
Compressible solvers deals with the Navier-Stokes flow energy equation, which is related to the flow temperature. Thus, temperature T and alphat (which I don't know what means) must be added to the boundary conditions.
| \\      /  F ield        | OpenFOAM: The Open Source CFD Toolbox          |
|  \\    /  O peration    | Version:  v2012                                |
|  \\  /    A nd          | Website:  www.openfoam.com                      |
|    \\/    M anipulation  |                                                |
FoamFile
    version    2.0;
    format      ascii;
    class      volScalarField;
        location    "0";
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField  uniform 298;
boundaryField
    #includeEtc "caseDicts/setConstraintTypes"
    inlet
        type            fixedValue;
        value          uniform 298;
    outlet
        type            zeroGradient;
    wall
        type            zeroGradient;
FoamFile
    version    2.0;
    format      ascii;
    location    "0";
    object      alphat;
dimensions      [1 -1 -1 0 0 0 0];
internalField  uniform 0;
boundaryField
    wall
        type            compressible::alphatWallFunction;
        value          uniform 0;
    inlet
        type            calculated;
        value          uniform 0;
        outlet
        type            calculated;
        value          uniform 0;
2. Add the density variable and its value to transportProperties file and create a thermophysicalProperties file
You must alter these files accordingly to your simulation altitude (i.e. rho = f(h) )
FoamFile
    version    2.0;
    format      ascii;
    class      dictionary;
    location    "constant";
    object      transportProperties;
transportModel  Newtonian;
rho            1.225;
nu              1.8e-05;
FoamFile
    version    2.0;
    format      ascii;
    class      dictionary;
    object      thermophysicalProperties;
thermoType
    type            hePsiThermo;
    mixture        pureMixture;
    transport      const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
mixture // air at room temperature (298 K)
    specie
        molWeight  28.96;
    thermodynamics
        Cp          1004.5;
        Hf          0;
    transport
        mu          1.82e-05;
        Pr          0.71;
                Ts                        116;
3. Add new variables to fvSchemes, fvSolution and create fvOptions file
You must add the new state variables of the flow related to energy and temperature.
I used the same configs from the aerofoilNACA0012 tutorial in fvSchemes
FoamFile
    version    2.0;
    format      ascii;
    class      dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default        steadyState;
gradSchemes
    default        Gauss linear;
    grad(p)        Gauss linear;
    grad(U)        cellLimited Gauss linear 1;
        grad(k)        cellLimited Gauss linear 1;
        grad(omega)    cellLimited Gauss linear 1;
divSchemes
    default        none;
    div(phi,U)      bounded Gauss linearUpwind limited;
    turbulence      bounded Gauss upwind;
    energy          bounded Gauss linearUpwind limited;
    div(phi,k)      $turbulence;
    div(phi,omega)  $turbulence;
        div(phi,epsilon)  $turbulence;
    div(phi,e)      $energy;
    div(phi,K)      $energy;
    div(phi,Ekp)    $energy;
    div(phid,p)    Gauss upwind;
    div((phi|interpolate(rho)),p)  bounded Gauss upwind;
    div(((rho*nuEff)*dev2(T(grad(U)))))    Gauss linear;
laplacianSchemes
    default        Gauss linear limited corrected 0.33;
interpolationSchemes
    default        linear;
snGradSchemes
    default        limited corrected 0.33;
wallDist
    method meshWave;
Add the energy equation solver and relaxation factors. It is also necessary to include rho in the relaxation factors. I used the same parameters as the tutorial.
I use potentialFlow to initialize the compressible simulation with an incompressible solution. nNonOrthogonalCorrectors in the SIMPLE section helps the solver when large pressure gradients appear in the flow.
FoamFile
    version    2.0;
    format      ascii;
    class      dictionary;
    object      fvSolution;
solvers
    "pcorr.*"
        solver          GAMG;
        tolerance      1e-2;
        relTol          0;
        smoother        DICGaussSeidel;
        cacheAgglomeration no;
        maxIter        50;
    p
        $pcorr;
        tolerance      1e-5;
        relTol          0.01;
    pFinal
        $p;
        tolerance      1e-6;
        relTol          0;
    "(U|k|epsilon|e)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance      1e-6;
        relTol          0.1;
    "(U|k|epsilon|e)Final"
        tolerance      1e-6;
        relTol          0;
SIMPLE
    //correctPhi          no;
    //nOuterCorrectors    2;
    //nCorrectors        1;
    nNonOrthogonalCorrectors 1;
        // Set up residual controls. Simulation stops when residual target is reached
        residualControl
                p                                        1e-6;
                //U                                        1e-4;
                //"(k|epsilon)"                1e-4;
potentialFlow
relaxationFactors
        fields
                p 0.3 ;
                rho 0.01 ;
        equations
                U 0.7 ;
                e 0.7 ;
                k 0.7 ;
                omega 0.7 ;
cache
    grad(U);
Create an fvOptions file to limit the temperature range and avoid getting non-physical values.
FoamFile
    version    2.0;
    format      ascii;
    class      dictionary;
    object      fvOptions;
limitT
    type      limitTemperature;
    min        101;
    max        1000;
    selectionMode all;
4. Change the forces or coefficients files if you use them
These files determines how the output forces and coefficients are printed by the solver. In incompressible flows, the rho = inf and the pressure is given by P = p/rho. Now that you have a finite density you must attribute its value to the files.
forces
    type          forces;
    libs          (forces);
    writeControl  timeStep;
    timeInterval  1;
    log          yes;
    patches      ("propeller.*");
    rho          rho;
    log          true;
    CofR          (0 0 0);    // Rotation around centre line of propeller
    pitchAxis    (0 1 0);
5. Change the dimension of pressure its value in 0/p file
Quoting the user snak:
In an incompressible solver, N-S equation is divided by a uniform density rho. This causes (1) the dimension of pressure of [0 2 -2 0 0 0 0] and (2) the kinematic viscosity nu in laplacian term. In an incompressible solver, pressure is assumed to be relative. The atmosphere will be 0 usually.
In a compressible solver, N-S equation is not divided by density. So, the dimension of pressure is [1 -1 -2 0 0 0 0] as usual. The dinamic viscosity mu appears in laplacian term. In a compressible solver, The absolute pressure is must be provided in p file because the value of pressure will be used to calculate other physical properies. The atmosphere will be 1e5 usually.
FoamFile
    version    2.0;
    format      ascii;
    location    "0";
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField  uniform 101325;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value          uniform 101325;
    wall
        type            zeroGradient;
snak September 3, 2021 12:39
Hi Gabriel,
Thank you for summarizing the procedure.
Some important points are missing in this guide. The dimension and type of pressure and the physical property of viscosity depend on the type of solver (compressible or incompressible). We have to adjust these as switch the solvers.
gabrielfelix September 3, 2021 12:45
Originally Posted by snak (Post 811579)
Hi Gabriel,
Thanks man! I forgot the pressure file changes. I'll add them to the guide. There are so many changes you gotta made that I took some of them for granted.
