June 11, 2021, 04:19 |
PimpleFoam for non-Newtonian flows
mohammad
Rep Power: 11 |
Hi everybody,
I am using the pimpleFoam solver for a yield stress Herschel-Bulkley flow. The question is about my setting in fvSolution script. Code:
PIMPLE { momentumPredictor on; nOuterCorrectors 15; nCorrectors 3; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; turbOnFinalIterOnly no; } Cheers, Mohammad Last edited by mostanad; June 11, 2021 at 08:12. |
September 1, 2021, 16:30 |
Francisco T
Rep Power: 14 |
If your problem is significantly turbulent, you might want to solve k and omega at each time-step, by setting this flag turbOnFinalIterOnly
If not, then save calculations and cpu tine |
September 3, 2021, 03:11 |
mohammad
Rep Power: 11 |
Hi Francisco
Thanks for your reply. What about a non-Newtonian flow which needs viscosity update? Mohammad |
September 3, 2021, 05:14 |
#4 | |
Francisco T
Rep Power: 14 |
As far as I understand, OpenFOAM includes a library of strain-rate dependent viscosity models, where they construct the viscosity as a field (scalar). This construction is function of some constants but also the strainRate() which is dependent on the flow conditions. You can visualize nu (viscosity) in paraview, and check that it is actually updated every iteration. |
pimpleFoam runs slower than rhoPimpleFoam | Kosuke Seto | OpenFOAM Running, Solving & CFD | 3 | May 27, 2023 14:12 |
Running pimpleFoam in steady state | trailer | OpenFOAM Running, Solving & CFD | 6 | January 24, 2023 03:07 |
QGDsolver - OpenFOAM computational framework for fluid flows based on regularized equ | mkraposhin | OpenFOAM Announcements from Other Sources | 7 | September 13, 2021 03:09 |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 18:19 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
