September 6, 2021, 05:12 |
div schemes error using Gauss linear
Horst van Gras
Rep Power: 7 |
I had already asked a question in a previous post: Negative Enthalpy and wrong temperature I could restrain my problem of wrong enthalpy and wrong temperature to the convection part of the energy equation in EEqn.h fvm:div(phi,h) in other words . When using the second order Gauss linear my enthalpy is dropping and the temperature falls under 293K, which is not physical. However when using Gauss upwind the enthalpy remains to it initial state, which is correct and the minimal temperature is still at 293K. Remark phi is very small in my case and I doubt that the second order linear scheme causes dispersion error and the dissipative upwind smooth the error out. Is this possible? |
energy equation, enthalpy, temperature |
Unstructured mesh made out of OF | sinatahmooresi | OpenFOAM Running, Solving & CFD | 7 | July 22, 2021 01:59 |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
Optimal tolerance and variables scaling settings | 4513645ygq | Main CFD Forum | 0 | July 28, 2020 08:56 |
2nd Order Convergence Problem for 3D Airfoil | turkmengokce | OpenFOAM Running, Solving & CFD | 1 | September 10, 2015 07:20 |
solution diverges when linear upwind interpolation scheme is used | subash | OpenFOAM | 0 | May 29, 2010 01:23 |
