daylen |
September 13, 2021 19:30 |
Flow around a square cylinder
Hi, im a beginner at cfd, im trying to simulate flow around a square cylinder in 2d, for this i used as template motorbike, is there a better template for this?, i have to use k-omega sst, steady state and simple algorithm, i made a blockMeshDict, but i donīt know what to do next, i get the following error:
blockMeshDict:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 9
\\/ M anipulation |
FoamFile
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 0.01;
vertices
(0 0 0) // 0
(40 0 0) // 1
(40 40 0) // 2
(0 40 0) // 3
(0 0 1) // 4
(40 0 1) // 5
(40 40 1) // 6
(0 40 1) // 7
(17.5 17.5 0) // 8
(22.5 17.5 0) // 9
(22.5 22.5 0) // 10
(17.5 22.5 0) // 11
(17.5 17.5 1) // 12
(22.5 17.5 1) // 13
(22.5 22.5 1) // 14
(17.5 22.5 1) // 15
blocks
hex (0 1 9 8 4 5 13 12) (10 10 1) simpleGrading (1 1 1)
hex (1 2 10 9 5 6 14 13) (10 10 1) simpleGrading (1 1 1)
hex (11 10 2 3 15 14 6 7) (10 10 1) simpleGrading (1 1 1)
hex (0 8 11 3 4 12 15 7) (10 10 1) simpleGrading (1 1 1)
edges
boundary
frontAndBack
type empty;
faces
(0 1 9 8)
(1 2 10 9)
(11 10 2 3)
(0 8 11 3)
(4 5 13 12)
(5 6 14 13)
(15 14 6 7)
(4 12 15 7)
inlet
type patch;
faces
(4 7 3 0)
outlet
type patch;
faces
(5 6 2 1)
bottom
type wall;
faces
(5 4 0 1)
top
type wall;
faces
(6 7 3 2)
obstacle
type wall;
faces
(13 12 8 9)
(13 14 10 9)
(14 15 11 10)
(12 15 11 8)
p:
\\/ M anipulation |
FoamFile
format ascii;
class volScalarField;
object p;
#include "include/initialConditions"
dimensions [0 2 -2 0 0 0 0];
internalField uniform $pressure;
boundaryField
//- Set patchGroups for constraint patches
#includeEtc "caseDicts/setConstraintTypes"
inlet
type zeroGradient;
outlet
type fixedValue;
value $internalField;
lowerWall
type zeroGradient;
motorBikeGroup
type zeroGradient;
#include "include/frontBackUpperPatches"
running simpleFoam error:
\\/ M anipulation |
Build : 9-12bcf7429695
Exec : simpleFoam
Date : Sep 13 2021
Time : 18:21:36
Host : "Mint19"
PID : 9624
I/O : uncollated
Case : /home/gabriel/OpenFOAM/gabriel-9/run/motorBike_1
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: No convergence criteria found
Reading field p
--> FOAM FATAL IO ERROR:
inconsistent patch and patchField types for
patch type empty and patchField type slip
file: /home/gabriel/OpenFOAM/gabriel-9/run/motorBike_1/0/p/boundaryField/frontAndBack from line 16 to line 16.
From function static Foam::tmp<Foam::fvPatchField<Type> > Foam::fvPatchField<Type>::New(const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&, const Foam::dictionary&) [with Type = double]
in file /home/ubuntu/OpenFOAM/OpenFOAM-9/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 157.
FOAM exiting
