Kryoleiche |
September 14, 2021 04:40 |
Duct flow with two fans - SimpleFOAM stops after first iteration
2 Attachment(s)
Dear foamers,
I'm working on a k-epsilon model of a rectangular, horizontal channel with two fans in parallel, an downward-facing inlet and a upward-facing outlet. The geometry was created using blender for the .STL files and snappyHexMesh for meshing and works fine by itself (tested without fans).
I've implented the fans using cyclic boundary conditions, as it is done in the TJunctionFan tutorial. The fan curves used are somewhat generic and not final.
As a mandatory boundary condition, air is streaming from the inlet with fixed velocity. This was realized using flowRateInletVelocity as a BC with a given volumetric flow rate.
However, upon evaluation, SimpleFOAM only does one iteration and then stops without an error (and without having reached conversion). According to the output file, this happens during the evaluation of the pressure field. I can't figure out if this is due to suboptimal BCs, poor numeric stability or suboptimal solver settings. Please see below for the input files, log files as well as screenshots from Paraview after the first iteration. Advice would be kindly appreciated.
0/p
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 9
\\/ M anipulation |
FoamFile
format ascii;
class volScalarField;
location "0";
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
inletJunction1
type zeroGradient;
inletJunction2
type zeroGradient;
sideFan
type zeroGradient;
sideFanJunction
type zeroGradient;
mainFan
type zeroGradient;
fanJunction
type zeroGradient;
channel
type zeroGradient;
outletJunction1
type zeroGradient;
outletJunction2
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
baffleFacesMainFan_master
type zeroGradient;
baffleFacesMainFan_slave
type zeroGradient;
cyclicFacesMainFan_master
type fanPressureJump;
patchType cyclic;
patchType cyclic;
jump uniform 0;
value uniform 0;
jumpTable
type polynomial;
coeffs
2
(0 9620)
(300 0)
cyclicFacesMainFan_slave
patchType cyclic;
patchType cyclic;
value uniform 0;
baffleFacesSideFan_master
type zeroGradient;
baffleFacesSideFan_slave
type zeroGradient;
cyclicFacesSideFan_master
patchType cyclic;
patchType cyclic;
jump uniform 0;
value uniform 0;
jumpTable
type polynomial;
coeffs
2
(0 9620)
(300 0)
cyclicFacesSideFan_slave
patchType cyclic;
patchType cyclic;
value uniform 0;
0/U
\\/ M anipulation |
FoamFile
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type flowRateInletVelocity;
volumetricFlowRate
type constant;
value 250;
extrapolateProfile 0;
value uniform (0 0 0);
inletJunction1
type noSlip;
inletJunction2
type noSlip;
sideFan
type noSlip;
sideFanJunction
type noSlip;
mainFan
type noSlip;
fanJunction
type noSlip;
channel
type noSlip;
outletJunction1
type noSlip;
outletJunction2
type noSlip;
outlet
type zeroGradient;
type fixedValue;
type fixedValue;
type cyclic;
type cyclic;
type fixedValue;
type fixedValue;
type cyclic;
type cyclic;
fvSchemes
\\/ M anipulation |
FoamFile
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss linearUpwind grad(U);
div(phi,k) bounded Gauss limitedLinear 1;
div(phi,epsilon) bounded Gauss limitedLinear 1;
div(phi,omega) bounded Gauss limitedLinear 1;
div(phi,v2) bounded Gauss limitedLinear 1;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
div(nonlinearStress) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
wallDist
method meshWave;
fvSolution
\\/ M anipulation |
FoamFile
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p
solver GAMG;
tolerance 1e-06;
relTol 0.1;
smoother GaussSeidel;
"(U|k|epsilon|omega|f|v2)"
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-05;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 0;
consistent yes;
residualControl // legt Grenzen (Änderung) für Konvergenz fest, Simulation endet, wenn erfüllt (auch wenn max. TimeSteps noch nicht erreicht)
p 1e-4; //1e-2;
U 1e-4; //1e-3;
"(k|epsilon|omega|f|v2)" 1e-4; //1e-4;
relaxationFactors // nahe 1 für schnelle Konvergenz, kleiner für mehr Stabilität
equations
// U 0.9; // 0.9 is more stable but 0.95 more convergent
// ".*" 0.9; // 0.9 is more stable but 0.95 more convergent
p 0.3;
U 0.7;
k 0.1; // instabil für größere Werte
epsilon 0.1; //0.5; instabil für größere Werte
R 0.95;
nuTilda 0.95;
checkMesh
\\/ M anipulation |
Build : 9-89839ae3b8cd
Exec : checkMesh
Date : Sep 14 2021
Time : 10:27:34
Host : "NB3391"
PID : 9979
I/O : uncollated
Case : /home/hor/OpenFOAM/hor-9/run/tutorials/incompressible/simpleFoam/Asse/Square/Parallel
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 136973
internal faces: 111485
cells: 38066
faces per cell: 6.52703
boundary patches: 19
point zones: 0
face zones: 4
cell zones: 0
Overall number of cells of each type:
hexahedra: 27606
prisms: 818
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 9642
Breakdown of polyhedra by number of faces:
faces number of cells
4 156
5 318
6 3042
7 68
9 5110
11 2
12 728
13 114
15 104
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
inlet 436 569 ok (non-closed singly connected)
inletJunction1 1510 1806 ok (non-closed singly connected)
inletJunction2 1270 1455 ok (non-closed singly connected)
sideFan 2480 2854 ok (non-closed singly connected)
sideFanJunction 3058 3797 ok (non-closed singly connected)
mainFan 3270 3656 ok (non-closed singly connected)
fanJunction 684 815 ok (non-closed singly connected)
channel 9116 10180 ok (non-closed singly connected)
outletJunction1 1270 1455 ok (non-closed singly connected)
outletJunction2 1510 1806 ok (non-closed singly connected)
outlet 436 569 ok (non-closed singly connected)
baffleFacesMainFan_master 108 152 ok (non-closed singly connected)
baffleFacesMainFan_slave 108 152 ok (non-closed singly connected)
cyclicFacesMainFan_master 4 17 ok (non-closed singly connected)
cyclicFacesMainFan_slave 4 17 ok (non-closed singly connected)
baffleFacesSideFan_master 108 152 ok (non-closed singly connected)
baffleFacesSideFan_slave 108 152 ok (non-closed singly connected)
cyclicFacesSideFan_master 4 17 ok (non-closed singly connected)
cyclicFacesSideFan_slave 4 17 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-2.5 -45 -7.5) (12.5 25 7.5)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (-2.91264e-16 -2.25216e-17 -2.48671e-17) OK.
Max cell openness = 3.29172e-16 OK.
Max aspect ratio = 2.67029 OK.
Minimum face area = 0.00521692. Maximum face area = 1.3035. Face area magnitudes OK.
Min volume = 0.000449515. Max volume = 1.33144. Total volume = 2312.49. Cell volumes OK.
Mesh non-orthogonality Max: 46.0156 average: 14.5037
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 1.38066 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
Log File
\\/ M anipulation |
Exec : simpleFoam
Date : Sep 14 2021
Time : 10:08:45
Host : "NB3391"
PID : 9625
I/O : uncollated
nProcs : 1
Create time
Create mesh for time = 0
SIMPLE: Convergence criteria found
p: tolerance 0.0001
U: tolerance 0.0001
"(k|epsilon|omega|f|v2)": tolerance 0.0001
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
RAS
model kEpsilon;
turbulence on;
printCoeffs on;
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 0;
sigmak 1;
sigmaEps 1.3;
No MRF models present
No fvModels present
No fvConstraints present
Starting time loop
Time = 1
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0264807, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0291994, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0326049, No Iterations 2
GAMG: Solving for p, Initial residual = 0.997383, Final residual = 0.0233767, No Iterations 1
time step continuity errors : sum local = 0.304401, global = -0.0817178, cumulative = -0.0817178
smoothSolver: Solving for epsilon, Initial residual = 0.00726389, Final residual = 2.33158e-05, No Iterations 1
smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.00262554, No Iterations 1
ExecutionTime = 0.48 s ClockTime = 1 s
Time = 2
smoothSolver: Solving for Ux, Initial residual = 0.445811, Final residual = 0.0293242, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.273752, Final residual = 0.00789025, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.334445, Final residual = 0.0262153, No Iterations 1
