Solver overwrites initialized field
Old   September 14, 2021, 09:14
Default Solver overwrites initialized field
FluentStarter is on a distinguished road
Hei foamers,
I stumbled above the following problem.
I'm running an LES of a combustion process which up to know worked fine. I copied the case and wanted to restart it with adding an ignition box. I have only one timestep file in my case folder, a previous time-step which I want to use to start the simulation from. I then use setFields for the ignition box, decompose the case, check the field and everything looks fine (checked the fields with paraview). However, after a single time step of the simulation suddenly the field in the injectors gets overwritten. Where there was fuel earlier, the mass fraction of all species is suddenly zero in the injector? In the other regions the mass fractions seem unchanged.
Do you have any suggestions where I could look for this error?
Maybe a few steps which you would check for possible sources?
Thanks in advance....
FluentStarter is offline   Reply With Quote
PEMFC model with FLUENT brahimchoice FLUENT 22 April 19, 2020 16:44
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
OpenFOAM floating point Error upuli OpenFOAM Programming & Development 5 June 20, 2016 04:19
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
[PyFoam] struggles with adopted solver AnjaMiehe OpenFOAM Community Contributions 2 January 26, 2013 07:50
