InterFoam - Pressure
Old   September 28, 2021, 10:53
Default InterFoam - Pressure
Miguel Hernandez
Miguel Hernandez is on a distinguished road
Hello everyone,
I am studying the interFoam solver, I am asking the more experienced ones the difference between p and p_rgh.
Is p the total pressure?
Is p_rgh = p - rho g h ? and so, is p_rgh the dynamic component of the pressure?
Thanks, regards.
Miguel Hernandez is offline   Reply With Quote
Old   September 29, 2021, 05:42
Michael Sukham
2538sukham is on a distinguished road
I think if you see, pd or p_rgh are actually calculated as pd (or p_rgh) = p - rho*g*h . so its the pressure minus the hydrostatic term. please refer to Rusche thesis to learn how pressure is discretized and solved. If you study the interFoam code, you will find that pressure is reconstructed. Atleast this is much what i know. cheers
2538sukham is offline   Reply With Quote
Old   September 29, 2021, 11:25
Michael Alletto
mAlletto will become famous soon enough
By decomposing the pressure in this way the definition of the boundary conditions is easier. A constant p value at the exit cannot be applied for cases where the gravity place a role. Gower you can apply a constant p_rgh value
mAlletto is offline   Reply With Quote
Old   October 1, 2021, 19:24
Anup Singh
Anup Singh is on a distinguished road
Yes, p is the total pressure.
P_rgh is the reduced pressure which is exactly the way you have defined.
But if you need a better explanation then there are other threads where it has been already discussed or refer to ferziger and peric.
You can also see its transformation from the following link where Hydrostatic pressure effects has been discused.
https://www.openfoam.com/documentati...orm-p-rgh.html
For its uses and understanding of interfoam: you can refer to the thesis of Henrik Rusche which explains it in great detail while following the framework of openfoam making it easier to understand.
Hope it helps
Anup Singh is offline   Reply With Quote
Old   October 2, 2021, 07:09
Miguel Hernandez
Hope it helps
Thank you for the replay.
Now there is a thing I do not understand.
In a simulation I’m currently working on, in paraFoam I have always p_rgh greater then p... Is it possible?
Old   October 2, 2021, 07:27
Anup Singh
Well, I am not entirely sure of the possibility but I also get it in my simulations.
If you wish to confirm your assumption then define another variable in parafoam as PP = p_rgh + rho g h
and see whether it is equal to p.
Also if you take a look at the equation then you will realize that even though you are adding (rho g h) to p_rgh. The contribution of g is -9.81 m/s2 which in scalar format equates to a negative contribution.
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 05:35
Discharge of Pressure Vessel into Pipe with Regulator gajowni2 System Analysis 0 October 31, 2015 18:57
strange pressure behaviour with symmetricPlane boudary condition - interFoam duongquaphim OpenFOAM Running, Solving & CFD 10 August 20, 2013 14:00
Pressure reference in cyclic interFoam AlmostSurelyRob OpenFOAM 7 February 16, 2011 09:58
interFoam pressure conservation AndrewB OpenFOAM 0 August 26, 2009 23:15
