chtMultiRegionFoam in Simple mode crashes even with no Heat Transfer!
Old   October 5, 2021, 05:12
Default chtMultiRegionFoam in Simple mode crashes even with no Heat Transfer!
Kumar
kishpishar is on a distinguished road
chtMultiRegionFoam when operated in Simple (steady state) mode is found to crash after a few iterations. This is noticed even when there is absolutely no heat transfer (keeping everything isothermal) - using OpenFOAM v8.
The attached 2D case illustrates this problem. It is a simple case of water flowing at high velocity through a narrow channel above a copper plate which is heated from below.
https://drive.google.com/file/d/1bf3...ew?usp=sharing
The case crashes after just 3 iterations with the message (crash report attached):
--> FOAM FATAL ERROR:
Negative initial temperature T0: -302.788
The case used to run perfectly fine with OF v6. Could anyone take a look please?
-Kumar
kishpishar is offline   Reply With Quote
Coupled Heat and Mass Transfer Mecroob OpenFOAM Running, Solving & CFD 1 July 12, 2020 19:24
Radiation heat transfer with P1 and chtMultiRegionFoam EliotSch OpenFOAM Running, Solving & CFD 2 December 17, 2019 17:27
New guy trying to solve his first simple Heat Transfer simulation. BhaluBear OpenFOAM 2 August 12, 2014 12:54
Simple heat transfer in tube case Gimlas OpenFOAM Running, Solving & CFD 2 July 2, 2013 14:05
Multiregion Heat Transfer + natural convection (water) with chtMultiRegionFoam fattychickenrun OpenFOAM 5 October 31, 2011 16:53
