Only last timestep data is written, despite controlDict settings
Like Tree1Likes
  • 1 Post By alok
Old   October 7, 2021, 11:47
Default Only last timestep data is written, despite controlDict settings
Alok
alok is on a distinguished road
Hi all,
I'm basing my simulation on the motorBike tutorial. My `controlDict` looks like this:
application     simpleFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         100;
deltaT          1;
writeControl    timeStep;
writeInterval   10;
purgeWrite      0;
writeFormat     binary;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable false;
functions
As far as I understand the `writeControl` settings, this should write out every tenth time step, i.e. 0, 10, 20, ..., 100. However, only the last time step is written to disk, just 100.
I've tried changing the `writeControl` setting to `runTime`, `adjustableRunTime`, modified the start and end times, but with no luck. I saw in another old post that included functions may be the issue, so I took them out (as you can see above), but that also didn't change anything.
I'm a beginner to OpenFOAM, so I feel like I'm making a simple mistake. Any advice on what to do?
I'm running v2012 on Ubuntu 20.04.
alok is offline   Reply With Quote
Old   October 7, 2021, 12:07
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hi Alok,
Where are you looking for your data? At the root of your case or in the processors directories?
The motorbike tutorial runs in parallel which means the data is distributed in the processor* directories. This is where the data is saved depending on your writeControl.
After the run, reconstructPar allows to reconstruct the data at the root of your case (one directory for each time step). In the motorbike tutorial, reconstructPar is used with the "-latestTime" option so it reconstructs only the last time step of the simulation.
Cheers,
Yann
Yann is offline   Reply With Quote
Old   October 7, 2021, 13:45
Talking
Alok
Ah perfect!
Re-running `reconstructPar` without the `-latestTime` flag did the trick. Thank you!
Yann likes this.
How to setup a simple OpenFOAM cluster? TommiPLaiho OpenFOAM Installation 3 October 27, 2013 16:15
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
No data is written into UDM ivanbuz Fluent UDF and Scheme Programming 1 August 13, 2009 19:49
ParaFoam : Written data doesnt have Full Regions Velan Main CFD Forum 0 January 12, 2009 04:55
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
