put a probe on moving wall (overSetMesh) OFv2106. |
October 15, 2021, 08:22 |
H.Ham
Rep Power: 7 |
Hi Foamers,
i work on solid plate impacting water (overCompressibleInterFlow). I want to put a probe on plate wall and store pressure and alpha.water in time. But my plate move, in this case i want that my probe also move with the same velocity. how to do this dear Foamers ? attached figure : alpha field (blue:water, red:air),the black frame within the domaine is the plate, and i want to put a probe in the bottom surface of the plate. best regrets, |
October 23, 2021, 13:11 |
Rep Power: 8 |
You can use the probe function object with fixedLocations set to false.
You can find many tutorials using that. Here is a way to find about them: Code:
grep -rn 'fixedLocations' $FOAM_TUTORIALS |
Rotating Cylinder (Moving wall vs Moving reference frame vs Sliding mesh) | hamed.majeed | FLUENT | 2 | January 17, 2017 12:18 |
Moving Wall Condition on a Curved Wall | qwe11rty22 | FLUENT | 3 | August 25, 2016 01:45 |
problem about a periodic moving wall | itsqi7 | FLUENT | 6 | January 31, 2013 15:54 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
moving wall BC problem | Sourabh | Main CFD Forum | 1 | August 8, 2006 07:47 |
