Why do probes always sample the same value?
2 Attachment(s)
Hi all,
Firstly, I am simulating the cavity flow with and without doors at 0.85 Mach. I have successfully completed the "without doors" analysis. However, in with doors case, I have a problem with probes that sample pressure value at every time step. My initial pressure value is 62100Pa. After some time steps, probes start to measure the same pressure value which is equal to half of the initial value until the end of the analysis. I have tried different schemes but the results are the same. When I check the mesh quality, everything seems ok. In "without doors" case probes were quite successful to catch pressure fluctuations but "with doors" case probes don't catch the pressure fluctuations. What could be the problem? thanks in advance.. Code:
/*--------------------------------*- C++ -*----------------------------------*\ Code:
/*--------------------------------*- C++ -*----------------------------------*\ Quote:
Where are your probes located? An image might change.
Do the physical fields change after that timestep? I suppose its rather not a problem with the sampling, since usually it works flawlessly. |
1 Attachment(s)
Firstly I would like to thank you for your reply,
My probes are located on the cavity floor (can be seen in the figure). In the "without doors" case my everything was fine, like you said probably it is not a problem with sampling... I checked the physical fields, freestream value starts with 278m/s and suddenly drops to very small values such as 1, 2.. However, my pressure value seems half of the initial pressure value again. I carried out another simulation using a different turbulence model and the same pressure value was measured very long time. After very long time pressure fluctuations commenced but fluctuations are about only 1-2 pascal. Is it a good idea to extend the end time of the analysis? I'm stuck on this problem. thanks in advance.. |
I have just now checked your BCs.
Things that might be a problem: 1. I see no inlet BC for U. Maybe its a copy paste error, since otherwise the simulation wouldnt even start? 2. You are setting the inlet for p to zeroGradient and the outlet to wavetransmissive. Depending on your inletBC for U, they might not form a closed system. You should try the following: either p and U as fixedValue at the inlet and the outlet waveTransmissive for p and U or totalPresse and pressureInletOutletVelocity for U at the inlet and for p and U waveTransmissive at the outlet or you try a massFlowRate-BC for U at the inlet. I think then setting p to zeroGradient is fine. |
