[waveFoam] Unknown patchField type waveVelocity for patch type patch
Old   November 12, 2021, 03:15
Unhappy [waveFoam] Unknown patchField type waveVelocity for patch type patch
Nghiep
Nghiep is on a distinguished road
Hi everyone, I am a new member. Please help me solve the following issue. I have successfully compiled the waves2Foam on OpenFOAM ESI 2106 and tried running the DTCHullMoving case with the same set of the OpenFOAM tutorial. I have just changed the U and alpha.water by the following:
0/U
boundaryField
atmosphere
type pressureInletOutletVelocity;
value uniform (0 0 0);
inlet
type waveVelocity;//zeroGradient;
refValue uniform ( 0 0 0 );
refGradient uniform ( 0 0 0 );
valueFraction uniform 1;
value uniform ( 0 0 0 );
and 0/alpha.water
boundaryField
//- Set patchGroups for constraint patches
#includeEtc "caseDicts/setConstraintTypes"
inlet
type waveAlpha;//zeroGradient;
refValue uniform 0;
refGrad uniform 0;
value uniform 0;
And the error happens below:
[6] Unknown patchField type waveVelocity for patch type patch
[6]: command not found
My questions are:
1. I'm wondering whether the waveVelocity has been replaced by zeroGradient boundary condition or not.
2. If the 1st question was wrong, how can I fix it to run the waveFoam with waveVelocity.
Thank you in advance.
Nghiep is offline   Reply With Quote
Old   January 18, 2022, 12:03
Tony Zhang
zyfsoton is on a distinguished road
0/U
boundaryField
atmosphere
inlet
and 0/alpha.water
boundaryField
inlet
refValue uniform 0;
refGrad uniform 0;
value uniform 0;
My questions are:
Hi, I think I had a similar issue. Instead of using waves2Foam, I am using OFv7 its own wave generation to simulate a ship in wave condition. All run smoothly but when it comes to interFoam, error reported: Unknown patchField type waveVelocity for patch type patch, and I have successfully run the DTCHullWave tutorial case without any error, please let me know if you have any idea to resolve this, any help will be appreciated!
Thanks,
Tony
zyfsoton is offline   Reply With Quote
Old   May 11, 2022, 03:11
mill
mill is on a distinguished road
Hi,I'm meeting the same question.waveVelocity may not work in 0/U
mill is offline   Reply With Quote
Old   May 11, 2022, 03:33
mill
I have find the solution.May be you can add into the controlDict like below.
libs
"libwaves.so"
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 15:16
singularity? mihaipruna OpenFOAM Running, Solving & CFD 5 April 24, 2012 18:18
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
