Boundary conditions for pressure in the interfom solver |
November 24, 2021, 01:25 |
Dmitriy
Hello!
My question is about computer modeling of the tank filling process. The geometry of the tank is depicted below. What kind of initial and boundary conditions should I specify in order to obtain the case when the pressure in the upper part of the tank (p1) is equal to 10^5 Pa (a constant value), and the pressure in the lower part (p2) is equal to zero (a constant value, providing vacuum conditions). Thank you in advance! |
filling tank, interfoam, pressure, p_rgh |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
