Alain Islas
Rep Power: 7 ![]() |
I am simulating the cooling of a hot block (uniform T = 1000 K) surrounded by water at 20°C. The water fills a perfect box and remains quiescient, while the solid block just rests at the bottom. I am in natural convection regime. However, since I want to capture the transient evolution of the BL, I refined the fluid cells proximate to the solid wall. iso-view.PNG fluid_fine_layer.PNG For the fluid/solid interface I am using Code:
type compressible::turbulentTemperatureCoupledBaffleMixed; Tnbr T; value $internalField; When I run the case with the fine mesh I get weird results, there is a cold spot at one of the walls of the block. After only 1 sec, the simulation diverges and throws the error: FOAM FATAL ERROR: Negative Initial Temperature T0: -3.1820139 fine_layer.PNG However, when I run the case with mesh with no-wall refinement, the simulation runs easily up to 50s and the results seem more reasonable. no_layer.PNG Does anyone know how to address this issue without sacrifying the near-wall cells? |
Display Modes | |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 04:13 |
