Disable OpenFOAM output
Old   November 23, 2021, 18:25
Default Disable OpenFOAM output
Russian Federation
fetc95 is on a distinguished road
Hi, dear colleagues.
Does anybody know is there a possibility to disable OpenFOAM solver output in a specific case? For example, if I run the solver through runApplication, its output is written in "log.<solverName>". Otherwise, it is written to std. But can I disable this output at all or set this output to be written only at writeTime?
fetc95 is offline   Reply With Quote
Old   November 24, 2021, 05:27
fanta is on a distinguished road
hi,
you can edit your controlDict. There are options for the dictionary keyword "writeControl", look here: https://cfd.direct/openfoam/user-guide/v9-controlDict/
HTH, fanta
fanta is offline   Reply With Quote
Old   November 24, 2021, 20:39
Russian Federation
Originally Posted by fanta View Post
hi,
HTH, fanta
Thanks, but unfortunately it does not seem to be my question. WriteControl is just an indicator how to interpret the number given in writeInterval to write out the solution results into time directiories. It is not related to output of the solver to the console.
Old   November 26, 2021, 04:22
JNSN's Avatar
Jan
JNSN is on a distinguished road
you can simply redirect the output to /dev/null:
whateverFoam > /dev/null
or, if you want to redirect both error and output messages:
whateverFoam > /dev/null 2>&1
Best,
Jan
JNSN is offline   Reply With Quote
openfoam, output to file
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
How to get the output pressure of OpenFoam? IGH OpenFOAM Post-Processing 3 October 4, 2017 10:38
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 03:19
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
