Simon
Rep Power: 13 ![]() |
Dear Foamers,
today I tested the new buoyancyTurbSource feature using the OF v2106 master branch. However, using the hotRoom tutorial with the fvOptions file as below, the run crashed. Without the fvOptions file it worked perfectly. constant/fvOptions Code:
buoyancyTurbSource1 { type buoyancyTurbSource; beta 3.3e-03; // Thermal expansion coefficient for incompressible cases rho rho; alphat alphat; T T; selectionMode all; } LOG: ... Selecting finite volume options type buoyancyTurbSource Source: buoyancyTurbSource1 - selecting all cells - selected 4000 cell(s) with volume 500 Applying buoyancyTurbSource to: epsilon and k Courant Number mean: 0 max: 0 .... Courant Number mean: 1.22152e+25 max: 2.19919e+26 Time = 56 PIMPLE: iteration 1 DILUPBiCGStab: Solving for T, Initial residual = 1, Final residual = 1.34532e-07, No Iterations 2 DICPCG: Solving for p_rgh, Initial residual = 0.999025, Final residual = 0.00123228, No Iterations 1 time step continuity errors : sum local = 4.44339e+23, global = 6.50956e+06, cumulative = 6.89475e+09 DICPCG: Solving for p_rgh, Initial residual = 6.37374e-11, Final residual = 6.37374e-11, No Iterations 0 time step continuity errors : sum local = 3.33592e+24, global = 3.54335e+07, cumulative = 6.93018e+09 DILUPBiCGStab: Solving for epsilon, Initial residual = 0.0435253, Final residual = 7.14145e-07, No Iterations 58 bounding epsilon, min: -1.09797e+67 max: 5.40352e+68 average: 1.83296e+66 DILUPBiCGStab: Solving for k, Initial residual = 0.843783, Final residual = 4.15889e-07, No Iterations 35 bounding k, min: -2.3265e+59 max: 1.81813e+59 average: 1.87383e+58 ExecutionTime = 0.42 s ClockTime = 0 s Courant Number mean: 1.28264e+25 max: 1.89296e+26 Time = 58 PIMPLE: iteration 1 DILUPBiCGStab: Solving for T, Initial residual = 1, Final residual = 3.74953e-07, No Iterations 2 DICPCG: Solving for p_rgh, Initial residual = 0.0478055, Final residual = 0.000377563, No Iterations 6 time step continuity errors : sum local = 8.32321e+30, global = -1.83838e+14, cumulative = -1.83831e+14 DICPCG: Solving for p_rgh, Initial residual = 9.1225e-72, Final residual = 9.1225e-72, No Iterations 0 time step continuity errors : sum local = 6.17026e+30, global = -3.54588e+14, cumulative = -5.3842e+14 DILUPBiCGStab: Solving for epsilon, Initial residual = 1.70957e-08, Final residual = 1.70957e-08, No Iterations 0 bounding epsilon, min: 5.06942e-23 max: 1.2042e+89 average: 1.62094e+88 #0 Foam::error: ![]() #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in /lib64/libpthread.so.0 #3 Foam::scalarProduct<double, double>::type Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::PBiCGStab::scalarSolve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #5 Foam::PBiCGStab::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #7 Foam::fvMatrix<double>::solveSegregatedOrCoupled(F oam::dictionary const&) at ??:? #8 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:? #9 Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<doubl e> > const&) at ??:? #10 Foam::RASModels::kEpsilon<Foam::IncompressibleTurb ulenceModel<Foam::transportModel> >::correct() at ??:? #11 ? at ??:? #12 __libc_start_main in /lib64/libc.so.6 #13 ? at ??:? First of all, everything seems to be fine, but at timestep 58 the solver crashed. Does anybody have an idea or experience with using buoyancyTurbSource? Greetings Simon |
Display Modes | |
