cyclicAMI+fixedJumpAMI
Hello, Nice to write to you.
It is the first time to write to you. Now I am calculating planer flow between to parallel plates. So, I wanna use cyclicAMI for velocity between inlet and outlet, together with jump condition for pressure. Namely, I want to give a pressure drop between inlet and outlet. However I am not sure to set the cyclicAMI and fixedJumpAMI. My setteng is as follows. I appropriately set the pressure drop as del p = 1.0 Pa in the following? If you give me some advices, I am very happy. My setting is as follows; 1) polymesh/boudary inlet { type cyclicAMI; nFaces 18; startFace 4224; matchTolerance 0.001; transform translational; separationVector (0.048 0 0 ); neighbourPatch outlet; } outlet { type cyclicAMI; nFaces 18; startFace 4242; matchTolerance 0.001; transform translational; separationVector (-0.048 0 0 ); neighbourPatch inlet; } 2) 0/p inlet { type fixedJumpAMI; patchType cyclicAMI; jump uniform 1.0; } outlet { type fixedJumpAMI; patchType cyclicAMI; } |
