Comparing CavitatingFoaM​ and InterPhaseChangeFoaM solvers (code)
Like Tree2Likes
  • 1 Post By JD_PM
  • 1 Post By JulioPieri
Old   January 28, 2022, 08:55
Default Comparing CavitatingFoaM​ and InterPhaseChangeFoaM solvers (code)
JD_PM is on a distinguished road
I am studying the differences between CavitatingFoaM​ and InterPhaseChangeFoaM.
The basics are clear: the former assumes compressible, isothermal flow and deals with a two phase, homogeneous mixture while the latter models incompressible, isothermal flow and deals with a two phase, immiscible flow.
I checked the code (for CavitatingFoaM​: https://www.openfoam.com/documentati...8C_source.html, for InterPhaseChangeFoaM: https://www.openfoam.com/documentati...8C_source.html) and only found the following remarkable difference:
In the Pressure-velocity PIMPLE corrector loop of InterPhaseChangeFoaM.C one finds
surfaceScalarField rhoPhi
IOobject
"rhoPhi",
runTime.timeName(),
mesh
mesh,
dimensionedScalar(dimMass/dimTime, Zero)
What does this piece of code really do? I found an old post (SurfaceScalarFields) regarding surfaceScalarField but did not really help me understand such piece.
Your replies will be highly appreciated
lxufeishi likes this.
JD_PM is offline   Reply With Quote
Old   February 4, 2022, 15:25
Julio Pieri
JulioPieri is on a distinguished road
I'm not familiar with those solvers, but this particular piece of code is just initializing a surfaceScalarField called rhoPhi as zero and with units of [kg/s].
surfaceScalarFields are fields of scalar (rather than vectors) valid at the surfaces of cells, such as fluxes. rhoPhi could be rho*phi, i.e, mass flux on faces.
JD_PM likes this.
JulioPieri is offline   Reply With Quote
Fully Coupled Solvers for OpenFOAM7+ (To be ported From FE4 code base) ELwardi OpenFOAM Programming & Development 4 January 7, 2024 04:54
No different caculation speed between serial and openMP code? AnhDL Main CFD Forum 4 May 16, 2020 05:17
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 13:30
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 16:56
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 09:10
