How to make CavitatingFoam non-isothermal
Old   February 2, 2022, 15:09
Post How to make CavitatingFoam non-isothermal
JD_PM is on a distinguished road
I want to understand how to make the CavitatingFoam solver (code here: https://cpp.openfoam.org/dev/cavitat...8C_source.html) non-isothermal.
To do so, I am comparing it to a similar solver that actually implements non-isothermal conditions: CompressibleInterFoam (code here: https://cpp.openfoam.org/dev/compres...8C_source.html).
By comparison, I see that the key has to be in how the pressure-velocity PIMPLE corrector loop is written for CompressibleInterFoam i.e. the key has to be in the following piece of code
// --- Pressure-velocity PIMPLE corrector loop
while (pimple.loop())
if (pimple.firstPimpleIter() || moveMeshOuterCorrectors)
// Store divU from the previous mesh so that it can be mapped
// and used in correctPhi to ensure the corrected phi has the
// same divergence
tmp<volScalarField> divU;
if (correctPhi)
// Construct and register divU for mapping
divU = new volScalarField
"divU0",
fvc::div(fvc::absolute(phi, U))
fvModels.preUpdateMesh();
mesh.update();
if (mesh.changing())
gh = (g & mesh.C()) - ghRef;
ghf = (g & mesh.Cf()) - ghRef;
MRF.update();
if (correctPhi)
#include "correctPhi.H"
mixture.correct();
if (checkMeshCourantNo)
#include "meshCourantNo.H"
divU.clear();
fvModels.correct();
#include "alphaControls.H"
#include "compressibleAlphaEqnSubCycle.H"
turbulence.correctPhasePhi();
#include "UEqn.H"
#include "TEqn.H"
Might you please hint me where should I focus on studying (moveMeshOuterCorrectors, ...?) in order to understand how to modify CavitatingFoam solver code in order to make it non-isothermal?
Thank you!
JD_PM is offline   Reply With Quote
[waves2Foam] Waves2Foam Related Topics ngj OpenFOAM Community Contributions 660 August 20, 2018 13:39
about CGNS nba1942 Pointwise & Gridgen 0 May 21, 2015 22:31
isothermal medium myaccount Main CFD Forum 0 January 22, 2014 06:42
[swak4Foam] Installing swak4Foam to OpenFOAM in mac Kaquesang OpenFOAM Community Contributions 22 January 21, 2013 12:51
how to make a series of plane with equidistance in postprossing of result sunxihui FLUENT 0 January 13, 2013 10:50
