Rep Power: 7 ![]() |
I still working on the simulation of fans using rhoSimpleFoam and MRF. I compare my results with the results from experimental tests and CFX simulation. The problem is I have a pressure to low on every running point... I have re-checked the geometry and the dimensions are OK. My mesh is OK according to checkMesh. Residuals seems to converge. But the result of OpenFOAM is 5% (on average) below the result of CFX. Do you have any idea why ? Here attached the case without the STL. Best regards, |
Display Modes | |
Pressure fields in FOAM, p field, total pressure, etc. | Tobi | OpenFOAM Post-Processing | 9 | March 25, 2022 01:33 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
Flow from low to high pressure | Lookid | Main CFD Forum | 4 | November 16, 2017 11:41 |
pressure diverge for pipeflow using rhoSimpleFoam | waq | OpenFOAM Running, Solving & CFD | 1 | June 25, 2015 08:38 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
