[Sponsors] | |||||
Rep Power: 5 ![]() |
I want to simulate (using OpenFOAM) a flow of water at an initial temperature (say 300 K) passing through a steel pipe at an initial temperature (say 90 K) and write two sets of equations: one that describes the fluid and other the solid. Then these two sets need to be coupled so that eventually both fluid and solid reach the same temperature.
For the fluid, I will use three conservation laws for mixture quantities (mass, momentum and total energy) and an additional equation for the void ratio (as explained in the paper "Modeling for non isothermal cavitation using 4-equation models"). If you want I can share the explicit equations. I have two main issues: 1) What equations should be used to model the steel? I thought of using essentially the same equations that for the fluid but I do not see how to modify them such that it models a solid. 2) How to couple both sets? I have been looking into the literature but I did not find a paper addressing a similar issue. Any help is appreciated
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Modelling blood flow in pipe | jzyk1212 | STAR-CCM+ | 2 | November 27, 2020 22:50 |
| Two-phase flow in a circular horizontal pipe | DmitryS | Fluent Multiphase | 0 | May 17, 2014 17:22 |
| New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
| modelling flow around flange pipe | rouz | FLOW-3D | 2 | March 24, 2009 22:39 |
| modelling for gas-solid flow in horizontal pipe | daninwin | CFX | 9 | February 8, 2001 00:47 |
