November 21, 2016, 05:32 |
SST transition
Xavier Lamboley
Rep Power: 11 |
I'm rather new to this forum but I wanted to share with you an adaptation I made of the gamma-Re_theta turbulence transition model for OpenFOAM 4.x. I used the tutorial available here, from the Chalmers Swedish University of Technology, but the (great) work they did was only for OpenFOAM 2.0.x. I still need to validate the results, if you could give me your feedback that would be awesome! To use it, the easiest is to have you own version of src/ in $WM_PROJECT_USER_DIR, and so just git clone git@gitlab.com:tilasoldo/openfoam_share.git. Your version of the executables will be used, since $PATH is defined with your src path first. Then compile the source: go in $WM_PROJECT_USER_DIR/src and run ./Allwmake. To use it, you must define in addition to what is needed for the k-omega SST: - initial conditions, fvSchemes and fvSolution for im (transition ratio) and Ret - constant/transitionProperties, which only contains the freeStreamU value. I also included in git the test case available in the tutorial, which sums up the usage of this solver. Let me know if you have any trouble to run or compile it, I could probably help Enjoy and have a nice day, X. Lamboley Last edited by tilasoldo; November 21, 2016 at 11:48. |
February 3, 2017, 05:01 |
Unto Kujansuu
Hi Tilasoldo,
I am also new to these forums and this is actually my first post here. I am currently working on implementing Menters new transition model (One equation LCTM 2015) in OpenFOAM 4.1. so it would be very helpful to have a peek how you managed to deal with OF4.x template metaprogramming. However, the link you provided isn't working anymore so is it possible to upload the model again? It could be interesting to compare the results of these models aswell. With regards Unto Last edited by Unzreal; February 7, 2017 at 06:28. |
February 10, 2017, 04:29 |
Xavier Lamboley
Rep Power: 11 |
Hi Unzreal,
I just retested my link and it works. However, it is a git link, you can download the source by running git clone git@gitlab.com:tilasoldo/openfoam_share.git in a terminal. If you prefer, I can provide direct download link: https://gitlab.com/tilasoldo/openfoa...tar?ref=master Let me know if this works for you. X.L. |
March 29, 2017, 05:30 |
Unto Kujansuu
Hi Tilasoldo,
Thank you!!! The code you provided functions almost perfectly and has been a great help for me. I've been so busy doing my impletation and running simulations I completely forgot to thank you for your effort. I made some minor changes to your code, so the freestream velocity can be read directly from a file. So far I've been running Schubauer-Klebanoff and ERCOFTAC flat plate simulations, comparing the new gamma model and your implementation of gamma-Re_theta model against experimental results. Seems that the newer model is even more sensitive to low y+ values (y+<0.01) than the prior model. Low y+ values results slow convergence and moves the transition downstream during iterations. In addition, I am getting some weird results from certain tests where gamma-Re_theta model does not work as it should. Probably it is due to bad initial values, not sure though. Will keep you updated! I attached some results from SK and T3A simulations if you are interested |
July 9, 2017, 18:29 |
Xavier Lamboley
Rep Power: 11 |
Glad to help, your result are very interesting too. This model is indeed very demanding in terms of mesh at the wall… I didn't try myself with the T3A and SC models but they seem to be accurate enough compared to their cost in CPU time I guess
Cheers! Sent from my iPad using CFD Online Forum mobile app |
March 15, 2022, 11:58 |
incompatible dimensions for operation in compressible case
shanghai
Hi, Sir
For compressible Case: [26] --> FOAM FATAL ERROR: [26] incompatible dimensions for operation [intermittency[1 -3 -1 0 0 0 0] ] - [intermittency[0 0 -1 0 0 0 0] ] ``` // Re_theta equation tmp<fvScalarMatrix> ReEqn ( fvm::ddt(alpha, rho, Ret_) + fvm::div(alphaRhoPhi, Ret_) - fvm::Sp(fvc::div(this->phi_), Ret_) == Ptheta*Reo_ - fvm::Sp(Ptheta, Ret_) ); ``` I change it to: ``` // Re_theta equation tmp<fvScalarMatrix> ReEqn ( fvm::ddt(alpha, rho, Ret_) + fvm::div(alphaRhoPhi, Ret_) - fvm::Sp(fvc::div(alphaRhoPhi), Ret_) == Ptheta*Reo_*alpha*rho - fvm::Sp(Ptheta*alpha*rho, Ret_) ); ``` It running.. Not sure it is corret or not? |
openfoam 4, solver development, turbulence |
turn off wall functions in Transition SST model? | johnp | FLUENT | 11 | May 26, 2020 13:57 |
Convergence Problems for Transition SST Turbulence Model | MrNavierStokes | FLUENT | 9 | September 25, 2017 16:25 |
Laminar-to-turbulent transition modelling using SST and SST Gamma Theta models | ttu004 | CFX | 3 | June 13, 2014 06:43 |
transition SST, transition happening near trailing edge of blade | gholamghar | FLUENT | 5 | October 4, 2013 04:16 |
to LANGTRY ROBIN :help, hypersonic transition SST | ben akih | CFX | 0 | September 21, 2006 04:59 |
