running fine in sequence but crash in parallel |
ff
Rep Power: 17 ![]() |
Hello Foamer,
I got a strange issue. My case is running fine in sequence mode, but if I decompose it and run in parallel. it just crash after a few iterations with U goes crazy. I tried a few times to use different decomposition method, and in oscationally with certain decomposition settings, it can be run in parallel. What is the best way to solve this? Thanks |
Ajith U K Nair
Rep Power: 5 ![]() |
does mpi run show any error message. Or is it crashing like a CPU deadlock where one CPU is waiting for the other.
check the processes by using 'top' command. 'mpirunDebug' may also help or you can write the run to a logfile and use 'tail -f 'filename'' to see what the error is |
#3 | |
ff
but if I just reconstruct the mesh and run in serial, it works and no velocity diverge happens. |
#4 | |
ff
Display Modes | |
[snappyHexMesh] reconstructPar after running snappyhexmesh in parallel | fidu | OpenFOAM Meshing & Mesh Conversion | 11 | October 20, 2020 09:01 |
[solids4Foam] HronTurekFsi3 Laminar Tutorial not running parallel using Foam-Extend 4.1? | EternalSeekerX | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 0 | May 29, 2020 03:12 |
Running AMI case in parallel | Kaskade | OpenFOAM Running, Solving & CFD | 3 | March 14, 2016 15:58 |
Case running in parallel gives error whereby running in serial works | Harak | OpenFOAM Running, Solving & CFD | 8 | October 17, 2015 11:12 |
parallel running | student666 | OpenFOAM Running, Solving & CFD | 7 | May 21, 2014 14:55 |
