Shif |
March 24, 2022 14:40 |
Floating point exception while running simpleFoam
Hello.
I am trying to do a simulation of a wind turbine blade (1/3 of the whole rotor) and have referred to the other thread on this forum for help every time I have encountered any problem.
Currently, I am encountering a "Floating Point Exception" when I run simpleFoam.
I have gone through some of the threads where others have faced the same issue and the first diagnosis recommended was to check their mesh. My checkMesh seems to have no problems, If it does have any issues that i have failed to identify please let me know
Create time
Create mesh for time = 0
Time = 0
Mesh stats
internal points: 328012
faces: 4346366
internal faces: 4226014
cells: 2143095
faces per cell: 4
boundary patches: 6
point zones: 0
face zones: 1
cell zones: 1
Overall number of cells of each type:
hexahedra: 0
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 2143095
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
cyclic1 7493 3860 ok (non-closed singly connected)
cyclic2 7493 3860 ok (non-closed singly connected)
inlet 1331 719 ok (non-closed singly connected)
inlet_top 6034 3125 ok (non-closed singly connected)
outlet 1319 713 ok (non-closed singly connected)
blade 96682 48343 ok (closed singly connected)
Checking faceZone topology for multiply connected surfaces...
FaceZone Faces Points Surface topology
interior-fluid 4226014 388190 multiply connected (shared edge)
<<Writing 388175 conflicting points to set nonManifoldPoints
Checking basic cellZone addressing...
CellZone Cells Points Volume BoundingBox
cellMRFZone 2143095 388192 5.15191e+06 (-135 -116.913 -180) (0 116.913 90)
Checking geometry...
Overall domain bounding box (-135 -116.913 -180) (0 116.913 90)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (-3.38768e-17 -3.01073e-16 -5.20473e-16) OK.
Max cell openness = 2.94847e-16 OK.
Max aspect ratio = 7.90672 OK.
Minimum face area = 0.000464667. Maximum face area = 91.3371. Face area magnitudes OK.
Min volume = 5.23826e-06. Max volume = 281.275. Total volume = 5.15191e+06. Cell volumes OK.
Mesh non-orthogonality Max: 63.8832 average: 16.2646
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.767696 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
My controlDict file is
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application simpleFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 1000;
deltaT 1;
writeControl timeStep;
writeInterval 50;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
functions
forces
type forces;
libs ("libforces.so");
writeInterval 50;
patches (blade);
// pname p;
// Uname U;
rho rhoInf;
log true;
rhoInf 1;
CofR (0 0 0);
fvSchemes
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss linearUpwind grad(U);
div(phi,omega) Gauss upwind;
div(phi,k) Gauss upwind;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
snGradSchemes
default corrected;
wallDist
method meshWave;
fvSolution
solvers
p
solver GAMG;
tolerance 1e-7;
relTol 0;
smoother GaussSeidel;
cacheAgglomeration no;
maxIter 500;
"(U|k|omega)"
solver smoothSolver;
tolerance 1e-7;
relTol 0;
nSweeps 2;
SIMPLE
nNonOrthogonalCorrectors 0;
consistent yes;
pRefCell 0;
pRefValue 0;
residualControl
p 1e-6;
"(U|k|omega)" 1e-6;
relaxationFactors
fields
p 0.3;
equations
"(U|k|omega)" 0.7;
my boundary conditions are as follows:
k:
FoamFile
version 2.0;
format binary;
arch "LSB;label=32;scalar=64";
class volScalarField;
location "0";
object k;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0.06;
boundaryField
blade
type kqRWallFunction;
value $internalField;
inlet
type fixedValue;
inlet_top
type fixedValue;
outlet
type zeroGradient;
cyclic1
type cyclicAMI;
cyclic2
type cyclicAMI;
nut:
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0;
boundaryField
blade
type nutkWallFunction;
inlet
type calculated;
inlet_top
type calculated;
outlet
type calculated;
cyclic1
type cyclicAMI;
cyclic2
type cyclicAMI;
omega:
FoamFile
version 2.0;
format binary;
location "0";
object omega;
dimensions [0 0 -1 0 0 0 0];
internalField uniform 4.5939;
boundaryField
blade
type omegaWallFunction;
inlet
type fixedValue;
inlet_top
type fixedValue;
outlet
type zeroGradient;
cyclic1
type cyclicAMI;
cyclic2
type cyclicAMI;
p:
FoamFile
version 2.0;
format binary;
location "0";
object p;
boundaryField
blade
type zeroGradient;
inlet
type zeroGradient;
inlet_top
type zeroGradient;
outlet
type fixedValue;
cyclic1
type cyclicAMI;
cyclic2
type cyclicAMI;
U:
FoamFile
version 2.0;
format binary;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 -10);
boundaryField
blade
type noSlip;
inlet
type fixedValue;
inlet_top
type fixedValue;
outlet
type zeroGradient;
cyclic1
type cyclicAMI;
cyclic2
type cyclicAMI;
Also one thing i noticed was when i run simpleFoam -dry-run i get this warning, I tried looking up for a solution but i couldnt find much resources
--> FOAM Warning :
From void Foam::faceZone::checkAddressing() const
in file meshes/polyMesh/zones/faceZone/faceZone.C at line 187
Illegal face index 21 outside range 0..20
could this warning be the root of the problem? I could not find any solution to fix this.
Thank you
