externalWallHeatFlux with non-uniform HF
Old   March 30, 2022, 04:26
Default externalWallHeatFlux with non-uniform HF
Luca
marluc is on a distinguished road
Dear Foamers,
I would like to use the BC "externalWallHeatFlux" by specifying a non-uniform value for the HF. Apparently this is possible, provided a Function 1 is used, as discussed in this post: Time varying externalWallHeatFlux
I did it with the expression syntax for a uniformFixedGradient but I also need to use the "thin wall" model and thus I should better use the externalWallHeatFlux.
Any suggestion or help is greatly appreciated.
BR,
Luca
EDIT:
The Function 1 cannot be used for my purpose. I guess that I have to write a new BC if I want to include a non-uniform HF in the "externalWallHeatFlux" BC of OF v2106.
As stated above I am able to define a non-uniform HF by using the expression syntax with "uniformFixedGradient" type BC but I cannot consider a wall thickness. If someone has an idea it is greatly welcome!
Luca
marluc is offline   Reply With Quote
Openfoam Turbulent Car Simulation meganrw OpenFOAM Running, Solving & CFD 0 July 5, 2021 16:50
Film cooling problem arun1994 OpenFOAM 0 October 26, 2020 10:08
rSF: p divergence in combustor (wt negative value) zonda OpenFOAM Pre-Processing 4 April 10, 2018 07:59
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 15:16
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 08:32
