Fixed TotalPressure at Inlet, but it still rises |
November 15, 2020, 06:00 |
Rep Power: 8 |
Hello everyone,
I am struggling with a weird phenomenon: I am doing a simulationen of an underexpanded jet with rhoCentralFoam. At the inlet I have a totalPressure, totalTemperature und zeroGradient for U and the outlet wavetransmissive for p and U and zeroGradient for T. Walls are slip (U) or zeroGradient (p,T). I have noticed, that that the totalPressure at the inlet rises. I have set the totalPressure to 10e5 Pa but he rises up to 23e5 Pa. Here are the boundary conditions for the Inlet: Code:
p: type totalPressure; phi phi; rho none; psi thermo:psi; gamma 1.4; p0 uniform 10e5; value uniform 10e5; T: type totalTemperature; gamma 1.4; phi phi; rho none; psi thermo:psi; T0 uniform 293.15; value uniform 293.15; U: type zeroGradient; Code:
p: type waveTransmissive; field p; psi thermo:psi; gamma 1.4; fieldInf 101325; lInf 1; value uniform 101325; T: type zeroGradient; U: type waveTransmissive; field U; phi phi; rho rho; psi thermo:psi; gamma 1.4; fieldInf (0 0 0); lInf 1; value uniform (0 0 0); Thank you! Friendly |
November 19, 2020, 02:35 |
Troy Snyder
Rep Power: 18 |
Are you sure that the total pressure on the inlet boundary patch itself rises, or the total pressure rises "close" to the inlet. I wonder if the inlet boundary patch may not be specified correctly and there is a sudden increase in total pressure just inside the computational domain.
November 23, 2020, 04:41 |
Rep Power: 8 |
yes, I am looking only at the inlet. I also think that my boundary conditions are wrong, so I searched for other works and those boundary conditions seem ok. I also wonder why the total pressure should rise. I think it is only possible if a closed vessel is filled with gas. But those boundary conditions shouldnt work like a wall. |
April 7, 2022, 12:29 |
Adrian Kwiatkowski
Did you manage to solve the case? |
[OLAFLOW] The OLAFLOW Thread | Phicau | OpenFOAM Community Contributions | 457 | March 27, 2024 00:59 |
totalPressure (why flux direction dependend) | Tobi | OpenFOAM Running, Solving & CFD | 3 | October 17, 2019 22:27 |
Reversed flow using pressure inlet and outlet? | here_for_help | FLUENT | 0 | September 28, 2018 15:20 |
Adjuting oulet pressure till inlet pressure reaches a certain value in timestep | pvpnrao | OpenFOAM Running, Solving & CFD | 2 | September 11, 2018 10:14 |
Looping over all faces within a boundary condition (turbulent inlet development) | Sevex | OpenFOAM Programming & Development | 5 | September 8, 2016 13:58 |
